I recently started putting together an expansion on my ZoneMinder setup. Part of that is a SV3C C22 https://www.sv3c.com/SV3C-PTZ-Security- ... 28875.html
I haven't been able to find much information on it. Honestly feels like I'm the only person who owns one.
I already got it setup as a monitor in ZM. The PTZ control sort of works with the Netcat ONVIF control type as others with SV3C ptz camera have used. The only thing that doesn't work is the Home and Presets, which I would like to try to get working. I do know the presets function on the camera side using its built in web portal. So the past couple of days I dug through the Netcat.pm script and tried multiple things. But I'm starting to reach the end of my knowledge and googlefoo. I know nothing about perl but have been learning a bit with my research into this.
One thing I haven't been able to figure out is these 400 responses the camera sends. Comes up on every command besides the Home command. Even the directional commands return this but those do work and move the camera.
07/20/23 09:46:35.205753 zmcontrol_6[2673].ERR [ZoneMinder::Control::Netcat:163] [After sending PTZ command, camera returned the following error:'400 Bad Request'
MSG:<s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope">
<s:Header>
<Security s:mustUnderstand="1" xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
<UsernameToken xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-secext-1.0.xsd">
<Username>MYUSER</Username>
<Password Type="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-username-token-profile-1.0#PasswordDigest">75hjjsyufehuisfhjk32f8shjk3=</Password>
<Nonce EncodingType="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-soap-message-security-1.0#Base64Binary"></Nonce>
<Created xmlns="http://docs.oasis-open.org/wss/2004/01/oasis-200401-wss-wssecurity-utility-1.0.xsd">2023-07-20T16:46:35Z</Created>
</UsernameToken>
</Security>
</s:Header><s:Body xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema"><Stop xmlns="http://www.onvif.org/ver20/ptz/wsdl"><ProfileToken>MainStream</ProfileToken><PanTilt>true</PanTilt><Zoom>false</Zoom></Stop></s:Body></s:Envelope>
Response:<?xml version="1.0" encoding="UTF-8"?><s:Envelope xmlns:s="http://www.w3.org/2003/05/soap-envelope" xmlns:e="http://www.w3.org/2003/05/soap-encoding" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:wsa="http://www.w3.org/2005/08/addressing" xmlns:xmime="http://www.w3.org/2005/05/xmlmime" xmlns:tns1="http://www.onvif.org/ver10/topics" xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:xop="http://www.w3.org/2004/08/xop/include" xmlns:tt="http://www.onvif.org/ver10/schema" xmlns:wsnt="http://docs.oasis-open.org/wsn/b-2" xmlns:wstop="http://docs.oasis-open.org/wsn/t-1" xmlns:tds="http://www.onvif.org/ver10/device/wsdl" xmlns:tan="http://www.onvif.org/ver20/analytics/wsdl" xmlns:tr2="http://www.onvif.org/ver20/media/wsdl" xmlns:trt="http://www.onvif.org/ver10/media/wsdl" xmlns:tev="http://www.onvif.org/ver10/events/wsdl" xmlns:tptz="http://www.onvif.org/ver20/ptz/wsdl" xmlns:timg="http://www.onvif.org/ver20/imaging/wsdl" xmlns:ter="http://www.onvif.org/ver10/error" xmlns:tmd="http://www.onvif.org/ver10/deviceIO/wsdl" xmlns:hikwsd="http://www.onvifext.com/onvif/ext/ver10/wsdl" xmlns:hikxsd="http://www.onvifext.com/onvif/ext/ver10/schema" ><s:Body><s:Fault><s:Code><s:Value>s:Receiver</s:Value><s:Subcode><s:Value>ter:ActionNotSupported</s:Value></s:Subcode></s:Code><s:Reason><s:Text xml:lang="en">Action Not Implemented</s:Text></s:Reason></s:Fault></s:Body></s:Envelope>]
