notify email recipient on error
Is there a way to make ZM send me an email when an error is encountered? I tried to write a filter and cant seem to find anything about error conditions.....
Re: notify email recipient on error
I use a program called logcheck to send me any errors that get logged to syslog. Then set ZM to log warnings to syslog. Works for me.
Can you be more specific on what kind of error/where the error is supposed to be coming from?
Im talking about an error that appears in the ZM log. Logcheck eventually sends me the entire log, 12 hours worth twice a day, but I was trying to get ZM (or something else) to notify me with an email message whenever a particular log event occurs within ZM. I would like to get an immediate notification for
8/28/24, 5:48:28 PM EDT web_php 1189091 WAR Login denied for user "XXXX"
9/2/24, 4:04:35 AM EDT zmc_m4 1126489 ERR Unable to open input rtsp://10.1.1.158:554/cam/realmonitor?channel=1&subtype=0 due to: Connection refused zm_ffmpeg_camera.cpp 368
If logcheck can do this, I dont know how to configure it.
If there isn't a way to do that inside Zoneminder, then I'd be watching e.g. /var/log/zm/zm.log with a separate process, and watching for your key phrases to come up -- e.g. using "tail -f" to follow the end of the log and "grep -e 'Login denied for user' -e 'Another error' -e 'And Another error'" to pick off specific messages or reg-exps of messages.
Cron and grep works for me:
https://wiki.zoneminder.com/SMS_Notific ... _HDD_Fails
It's somewhat unfortunate to say that ZM needs monitoring scripts in order to run, as things are always breaking, but I don't know how it can be built into ZM without being more bloat. Maybe there can be optional shell scripts that are included in /usr/share/zoneminder. I've just made my own over time. Or you can use dedicated monitoring software but that has its own learning curve.
fastest way to test streams:
