I have found a very minor bug.
Such as:
When doing a clean install, while inserting SQL statements from the zmschema.sql, MySQL may not install the default admin user and stop processing further.
That is because the original zmschema.sql created by zmconfig.pl does not have the exact same number of fields for the admin user as in the database User table schema.
I changed the default zmschema.sql to read:
INSERT INTO Users VALUES ('', 'admin', PASSWORD( 'admin' ) , '', 1, 'View', 'Edit', 'Edit', 'Edit', 'Edit', '', '');
In this case you would have to re-adjust the settings for the admin user using the web interface. This would be necessary however for the first run, to change the default password and etc.
Regards,
Koray
