I bought and switched to the new zmninja but push messages arent working
aarons6
Post by aarons6 »
i migrated from the old zmninja-pro to the new zmninja, but push messages still arent working. its the one part of the app i really liked because i have object recognition on my zm server and the alerts were pretty accurate.
does the app no longer send push notifications? or was there some other settings i need to do?
the app is completely working fine, i can see all my cameras and they stream and have no issues viewing the events. i have all the ports setup and use HTTPS on my server.
im not getting any error messages, and the logs say a push message was sent. its just not showing up on my phone. i have tried turning it off and back on again. ive also deleted the token.txt file and generated a new one.
i know i can setup my own FCM server and do my own push messages. i was just wondering if this was still a default option for the app.
baudneo
Re: I bought and switched to the new zmninja but push messages arent working
Post by baudneo »
I would recommend pushover for now. There is work being done to get zmninja back into push messages, but apple build requirements are ludicrous.
aarons6
Post by aarons6 »
im using the android version
Thanks for purchasing, we will figure this out!
My understanding was that it should work with the new version.
Okay, I got it working today.
I don't know if the fcm url and key in your zmeventnotification.ini are correct, so you may try the following values:
#fcm_v1_key = myspecialkey
fcm_v1_key=eyJhbGciOiJIUzI1NiIsInR5cCI6IkpXVCJ9.eyJnZW5lcmF0b3IiOiJwbGlhYmxlIHBpeGVscyIsImlhdCI6MTcyNzQ0OTI1MCwiY2xpZW50Ijoiem1uaW5qYSJ9.2to4a_X0EQ8MtXyNzVCHfftn6zDn6QpwlSjVYicUq8I
# fcm_v1_url = https://my_custom_url/function_name
fcm_v1_url=https://us-central1-zoneminder-ninja.cl ... /send_push
zmNinja has to be able to talk to zmes at least once. SO while on local lan or whatever, run zmninja. THis will give zmes a token for your zmninja and fcm notifications should start working.
They do for me.
aarons6
Post by aarons6 »
awesome thanks for the reply.
i did not have any of those in my zmeventnotification.ini.
i changed the url and the key in the zmeventnotification.pl file because it was not what you posted.
now i deleted the token.txt and made zmninja make a new key and IT WORKS!!
thanks so much..
you need to edit the github and change the key and url in the zmeventnotification.pl because its wrong.
warcanoid
Post by warcanoid »
I dont get it on ios
We havn't been able to push a new IOS version yet. I think we are close though.
warcanoid
Post by warcanoid »
thank you very much for your affort, great work
Gipo
Post by Gipo »
Any update to iOS push fix? I have event server working nicely and pushing to Android tablet but would like to make use of the iOS app I just purchased.
