Mariadb ERROR 1698 (28000) on Debian 12 install
mdm55
Post by mdm55 »
I followed the instructions for Debian 12 (Bookworm) provided here:
https://zoneminder.readthedocs.io/en/la ... 1-bullseye
and at
Step 5: Configure database
mariadb -u zmuser -p zm < /usr/share/zoneminder/db/zm_create.sql
I received the following error:
ERROR 1698 (28000): Access denied for user 'zmuser'@'localhost'
The installed version of mariadb is Server version: 10.11.6-MariaDB-0+deb12u1 Debian 12
zm.conf shows:
# ZoneMinder database name
ZM_DB_NAME=zm
# ZoneMinder database user
ZM_DB_USER=zmuser
# ZoneMinder database password
ZM_DB_PASS=zmpass
Any suggestions?
rcrail
Re: Mariadb ERROR 1698 (28000) on Debian 12 install
Post by rcrail »
Were you able to resolve this issue? I have same problem.
rcrail
Post by rcrail »
My fix was to run:
a2enconf zoneminder, then
systemctl reload apache2, which failed with "Invalid command 'RewriteEngine', perhaps misspelled or defined by a module not included in the server configuration".
entered: a2enmod rewrite && sudo service apache2 restart, then
systemctl restart apache2
systemctl reload apache2.service
systemctl restart zoneminder.service
blaczero
Post by blaczero »
mdm55 wrote: Wed May 01, 2024 6:45 am I followed the instructions for Debian 12 (Bookworm) provided here:
and at
zm.conf shows:
ZM_DB_NAME=zm
ZM_DB_USER=zmuser
ZM_DB_PASS=zmpass
Any suggestions?
You would not run the zoneminder instruction as the SQL user to create the db. See the readme:
or
sudo mysql < /usr/share/zoneminder/db/zm_create.sql
You have zmuser in there as the account running the sql script
