Network triggering examples?
JimS
Post by JimS »
I am wanting to do some triggering from other devices on my network. Zoneminder is on a PC and I want to send triggers from raspberry pi or esp32 or the like. When I looked a the wiki it said to enable triggers:
Thing is I didn't find that option. Guessing it has moved on the newer version? I did find Opt_Triggers under system. Is that the same thing?
The wiki is a bit light on examples IMHO. Where would I find more examples? I did a bit of googling - maybe I am not using the correct terms...
JimS
Re: Network triggering examples?
Post by JimS »
I found a couple other pages on this. This one covers camera triggers but also notes the item I found is the proper one.
https://wiki.zoneminder.com/How_to_use_ ... on_with_ZM
And here's a bit more detail on how it works.
https://sparxeng.com/blog/software/zone ... riggering
I've recently added some new trigger stuff, all through the UI, so you don't have to use the trigger daemon. This is in 1.37.64
If you use a url like /zm/index.php?request=trigger&action=on&score=10&cause=cat&showtext=hello
Basically the query string maps to the same fields as you would send to zmtrigger.
