Log Errors Immediately after installing
Smack2k
Post by Smack2k »
I install zoneminder fresh on an ubuntu 22.04 server.
Immediately these errors start showing in the logs
Invalid log create: Array( [__csrf_magic] => key:395a26d018608d4bb71bc51b411390094640f752,1729854591 [view] => request [request] => log [task] => create [level] => ERR [message] => [browser] => Array ( [name] => Chrome [version] => 129.0.0.0 [platform] => Windows ) [file] => ?view=log)
Any idea what these are and why its mentioning my Chrome browser? Should I not use Chrome for zoneminder?
Re: Log Errors Immediately after installing
SOmething is causing a javascript error, but for some reason it isn't reporting the actual error, which makes it invalid.
Check your javascript console to see what the actual errors are.
You can turn off reporting the errors using Options->Logging->LOG_INJECT
Smack2k
Post by Smack2k »
Thanks for the help on turning off the errors
I ended up reinstalling my entire server due to other issues
