Hi I'm a newbie and have v1.36.33 running in a Proxmox container with 8cores/16G.
I'm created monitors for 4 Anpviz IP cameras (3 5MP, 1 4MP) and havent had issues
but when I try modect mode, the load goes way and I'll started getting the "Can't keep up ..." messages
I beleive thie issue is that I'm trying to analyze too much data at that
abd that the general advice seems to be to create a substream and only analythe the substream.
My Camera ui shows a substream options but how do I know what the url is of teh substream.
My working main stream url is. rtsp://<user>:<pass>@<ip-addr>:554/live/mpeg4
which I got from https://wiki.zoneminder.com/Hardware_Compatibility_List
newbie question on SourceSecondPath
Re: newbie question on SourceSecondPath
SourceSecondPath is for a separate audio stream. Someday it might be for the substream, but thus far has not been implemented.
Google for linked monitors.
1.36.33 is old and has security vulnerabilities. I would encourage you to upgrade.
1.37 series has more options for using less cpu.
You should also consider a reduced frame rate. Security video is frequently 10FPS and lower. TV shows are 24FPS.
An 8MP camera @ 8FPS doing modect takes ~50% of one of my Xeon threads. That may help you.
Another thing that will help later, increase your key frame rate. My key frames are once a second.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
So is this how it's supposed to work?
The lowres mon is in modect, the hires mon in monitor mode.
When movement is detected in lowres, the linked monitor starts to record?
I have:
"left" monitor is streaming 3072x2048 and
"left_lowres" monitor is streaming at 704x576 D1 PAL
left (hi res) monitor has as a linked (low res) monitor
I have:
- Screen Shot 2024-10-31 at 21.19.40 PM.png (134.01 KiB) Viewed 1402 times
You want nodect mode for the high rest, not monitor.
