Questions on events
blaczero
Questions on events
Post by blaczero »
Hey all, few questions about events.
#1 is there a way to turn off delete confirmation? I cannot find it
#2 I have so many events for each monitor. How do I manage the sensitivity for event trigger?
#3 As I said in #2, I have events constantly, but I do not have page buttons to cycle back through events, I can only see the first 20 and have to delete to see more.
Re: Questions on events
Re #3 -
I think what you want is to select the events from the console, at least for deleting.
Maybe the pagination is hidden? Try the toggle at the top right of the list.
IN 1.37 not sure about 1.36 you can hold shift when deleting.
Quantum
Post by Quantum »
1. Probably in Options.
2. Well it's called ZONEMinder, because it minds zones. You can adjust the zones for each monitor to any trapezoidal or pentagoheximal shape you need, to ignore areas you don't care about and reduce CPU. There are different types of zones you can add. RTFM.
