draw border around detected motion
petric
Post by petric »
is it possible to mark the detected movement in the recording triggered by modect. For example by drawing a red rectangle around it.
It would make it easier to see where the change is.
regards
Andyrh
Re: draw border around detected motion
Post by Andyrh »
In the monitor config under Storage change Save JPEGs to Frames + Analysis images (if available) When you view the frames it will have lines.
Note that will use more CPU and disk space.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
petric
Post by petric »
Thank you for your hint.
If i view the single frames i see the lines.
Why not embed it into the event when displaying the movie itself. It is very time consuming checking the frames instead.
Or did i miss a configuration setting ?
Andyrh
Post by Andyrh »
Just in the frames as far as I know.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
petric
Post by petric »
Could that be a feature request ?
I'm working on it. Actually working on just storing the info in the db and drawing it on demand.
Needs more funding though as always. No time to work on it.
petric
Post by petric »
Thanks for your feedback. So i know now its on the list.
I appreciate your and others work.
