Trying to setup a docker test env.
GadgetChris
Post by GadgetChris »
At https://github.com/ZoneMinder/zoneminder/wiki/Docker it describes the setup of a dev environment in docker.
I'm trying to follow it, and it's complaining about :
chris@aurora:~/dev/zm-docker$ docker buildx build -t='linuxlover9/release-1.36.33' github.com/ZoneMinder/zoneminder
[+] Building 8.6s (1/1) FINISHED        docker:default
 => [internal] load git source github.com/ZoneMinder/zoneminder                                                    8.4s
ERROR: failed to solve: failed to read dockerfile: open /var/lib/docker/tmp/buildkit-mount3288439779/Dockerfile: no such file or directory
The same happens when trying to use my own branch.
chris@aurora:~/dev/zoneminder$ docker build -t='linuxlover9/release-1.36.33' .
[+] Building 0.2s (2/2) FINISHED        docker:default
 => [internal] load build definition from Dockerfile                                                               0.1s
 => => transferring dockerfile: 2B        0.0s
 => [internal] load .dockerignore        0.1s
 => => transferring context: 45B        0.0s
ERROR: failed to solve: failed to read dockerfile: open /var/lib/docker/tmp/buildkit-mount1151009449/Dockerfile: no such file or directory
Clearly this is my first attempt setting up a dev env for ZM.
:wink:
I see there is a separate project https://github.com/ZoneMinder/zmdockerf ... Dockerfile
I'm not sure how to marry the two together to be able to run my code :?:
zm-v1.36.33 in docker @ Ubuntu 22.04.4.LTS
GadgetChris
Re: Trying to setup a docker test env.
OK, I have test docker running from source zoneminderhq/zoneminder:latest-ubuntu18.04.
How can I run my local code?
Do I have to do a cmake? what are the options?
GadgetChris
Seems the Dockerfile is missing.
Found zmdockerfiles https://github.com/ZoneMinder/zmdockerf ... Dockerfile
With the following result:
~/dev/zoneminder$ docker build -t linuxlover9/zm-1.36.33-chk .
[+] Building 4.1s (7/10)        docker:default
 => => transferring dockerfile: 4.88kB        0.0s
 => [internal] load .dockerignore        0.0s
 => [internal] load metadata for docker.io/library/ubuntu:impish                                                   0.7s
 => [1/7] FROM docker.io/library/ubuntu:impish@sha256:ff46b78279f207db3b8e57e20dee7cecef3567d09489369d80591f150f9  1.5s
 => => resolve docker.io/library/ubuntu:impish@sha256:ff46b78279f207db3b8e57e20dee7cecef3567d09489369d80591f150f9  0.0s
 => => sha256:240a11a56faca317f3355b143b5cc2791ba60ad0edd393b3ae3c85c29cad1a6c 529B / 529B                         0.0s
 => => sha256:50398b9058c55fa969c8ab5db6a11ff52686a9b6738884a9113d164dc567dfac 1.46kB / 1.46kB                     0.0s
 => => sha256:54b8fda3c9de3a40f0891ce200de55fc92e825315021192957f1bfe3fc807d7d 30.38MB / 30.38MB                   0.6s
 => => sha256:ff46b78279f207db3b8e57e20dee7cecef3567d09489369d80591f150f9c8154 1.42kB / 1.42kB                     0.0s
 => => extracting sha256:54b8fda3c9de3a40f0891ce200de55fc92e825315021192957f1bfe3fc807d7d                          0.6s
 => [2/7] RUN echo 'apt::install-recommends "false";' > /etc/apt/apt.conf.d/00recommends                           0.6s
 => [3/7] RUN apt-get install --reinstall -y gpgv        0.4s
 => ERROR [4/7] RUN apt-get update        0.7s
 > [4/7] RUN apt-get update:
0.507 Ign:1 http://security.ubuntu.com/ubuntu impish-security InRelease
0.525 Ign:2 http://archive.ubuntu.com/ubuntu impish InRelease
0.527 Err:3 http://security.ubuntu.com/ubuntu impish-security Release
0.527   404  Not Found [IP: 91.189.91.81 80]
0.553 Ign:4 http://archive.ubuntu.com/ubuntu impish-updates InRelease
0.579 Ign:5 http://archive.ubuntu.com/ubuntu impish-backports InRelease
0.604 Err:6 http://archive.ubuntu.com/ubuntu impish Release
0.604   404  Not Found [IP: 91.189.91.81 80]
0.629 Err:7 http://archive.ubuntu.com/ubuntu impish-updates Release
0.629   404  Not Found [IP: 91.189.91.81 80]
0.655 Err:8 http://archive.ubuntu.com/ubuntu impish-backports Release
0.655   404  Not Found [IP: 91.189.91.81 80]
0.659 Reading package lists...
0.669 E: The repository 'http://security.ubuntu.com/ubuntu impish-security Release' does not have a Release file.
0.669 E: The repository 'http://archive.ubuntu.com/ubuntu impish Release' does not have a Release file.
0.669 E: The repository 'http://archive.ubuntu.com/ubuntu impish-updates Release' does not have a Release file.
0.669 E: The repository 'http://archive.ubuntu.com/ubuntu impish-backports Release' does not have a Release file.
Dockerfile:15
  13 |     RUN apt-get install --reinstall -y gpgv
  14 |
  15 | >>> RUN apt-get update
  16 |
  17 |     RUN apt-get install -y \
ERROR: failed to solve: process "/bin/sh -c apt-get update" did not complete successfully: exit code: 100
Any hints, to get this noob further on my way, would be appreciated...
Thank you, GadgetChris
burger
Post by burger »
GadgetChris wrote: Sat Mar 23, 2024 6:53 pm Seems the Dockerfile is missing.
Dockerfile:15
  14 |
  16 |
It's unable to connect to the ubuntu repos. In my experience, this is usually a DNS issue, but it seems to have the IP address so maybe it's just a routing issue. If you run the container and have it idle at the end, can you login to the container and manually connect to the repos with wget or ping? Maybe the repo URL has changed. Maybe it's a firewall issue between docker and your computer.
The situation with Docker and ZM, is the following:
1) the devs aren't really working on it, it's only been from volunteers who have made some images. So you are mostly on your own
2) this should be posted in the docker forum
3) this looks like a fundamental docker troubleshooting issue that is not related to ZM. You might want to familiarize yourself with Docker a bit more. I've recommended the book by Adrian Mouat a couple times (although it's older, but probably still relevant).
I doubt anything with ZM and docker is difficult, but it's a timesink and so far people just haven't had the bandwidth to work on it. Finally, you should look through the docker forum to see what else is available. From my memory you should be able to find a working ZM configuration, but might have trouble finding one with ZMES and MLAPI.
fastest way to test streams:
kennaanna
Post by kennaanna »
GadgetChris wrote: Mon Mar 18, 2024 1:17 am At https://github.com/ZoneMinder/zoneminder/wiki/Docker the innocence test it describes the setup of a dev environment in docker.
:wink:
It seems like the Dockerfile is missing. Make sure it's in the root of your project directory. If you cloned the repo, double-check its location. You can also try adjusting your build command to specify the correct path. Good luck!
