Hi
I am trying to change my log roatation so that Zonemidner is not restarted at midnight.
As far as I can tell the postrotate calls "zmpkg.pl logrot" which in turn calls "zmdc.pl logrot" and simply does some checks then restarts the zoneminder process from its pid.
If I change logrotate to use copytruncate, can I safely remove the postrotate command, or is it doing somethign else I have not noticed?
Phil.
Question: zmpkg.pl logrot
Re: Question: zmpkg.pl logrot
The logrot command send SIGHUP to all processes. Some will just restart, others don't restart, they close their log files and re-open them. This is so that they don't keep writing to the rotated log.
I don't know what the effect of copy + truncate would be
