When I look at https://zmrepo.zoneminder.com, the most recent fedora build is from 8/2024 for fedora 39. But fedora 39 is EOL and there have been 2 releases since then.
I upgraded to zoneminder 1.37 about a year ago on my fedora server, and now I'm on fedora 40. I am limping along with an old fedora 39 zoneminder package on this system (had to downgrade my gsoap packages to satisfy dependencies). I'm afraid I won't be able to upgrade to current fedora 41 with the old zoneminder package, so I am in search of a better path forward.
Any current zoneminder 1.37 builds for fedora?
Re: Any current zoneminder 1.37 builds for fedora?
I did build my own fedora 40 and fedora 41 rpms for 1.37.65.
Took some updating of the RPM spec file that hasn't been maintained, and also jwt-cpp which tries to install (apparently) unnecessary stuff that rpmbuild objects to.
I could make diffs but there seems to be no interest here...
I'm sure lots of people would appreciate builds for newer fedora. Patches are definitely welcome.
Ok, here it is:
I took out the CAMBOZOLA config option default that is no longer an option in 1.37, and removed ZM_OPT_CONTROL as well since the default was already set as desired.
I also added the new 1.37 files to be included in the rpm.
Patch to jwt removes the development files from the installation (which were triggering rpmbuild errors).
- jwt-patch.txt
- (1.6 KiB) Downloaded 185 times
- spec-patch.txt
- (918 Bytes) Downloaded 185 times
Thanks I'll try to merge them this weekend.
Any luck with this? Yes, updates of 1.37 would be very much appreciated on the Fedoras and RHELs too. Is ZMRepo no longer building anything?
Regards,
Mark
Regards,
Mark
