TP-Link Tapo C200 control script
oparm
Post by oparm »
Hello everyone,
I created a control script for the Tapo C200. It works quite well :)
https://github.com/oparm/zoneminder-tapo-c200
The script is simple to use I think but if you have issues, questions or remarks, feel free to post here or create an issue directly on github.
Enjoy
zackfuchtel
Re: TP-Link Tapo C200 control script
Post by zackfuchtel »
tried to use, but not working for me. Got this error:
zmcontrol_1[1034123].ERR [ZoneMinder::Control::TapoC200:169] [Invalid credentials for https://172.31.100.250:443, exiting]
zmcontrol_1[960770].FAT [ZoneMinder::Control:68] [0 not object from ZoneMinder::Control::TapoC200:170]
Double checked multiple times, the password is correct. Perl modules are loaded. Zoneminder is v1.36.3 on AlmaLinux 8.4. As I asume, Zoneminder cannot load/read the TapoC200.pm or its values correct?
Thanks for help.
pat2
Post by pat2 »
thanks a lot for the script. It works!
I use it on Ubuntu 16.04. On 16.04 it is not possible to install the seccond library you suggested
sudo apt install libjson-pp-perl libjson-parse-perl
I commented in your script
#use JSON::Parse 'parse_json';
it worked!
thanks
Shadow
Post by Shadow »
Hello, I have 3 cameras, and like 6 devices in zoneminder because they keep changing between 2 ip . All camera seem to change between 2 ip numbers, is it possible to turn on all privacy in one click and turn priivacy on in one click?
Thanks,
Shadow
Shadow, you should start a new thread. Even if your cameras are Tapos. Mention what network equipment you have.
gabrielhopkins
Post by gabrielhopkins »
Thank you very much - this works great!!
Ramblin
Post by Ramblin »
Thank you!
I can confirm that this works with TapoC520WS
It requires the addition of the libraries you mentioned for JSON and JSON::Parse but once that was done, it worked.
As for @pat2 who said they could not install the second library using "apt install libjson-parse-perl" , there is always the option of installing via cpan
cpan JSON
cpan JSON::Parse
Using cpan requires make so if you do not already have it,
apt install build-essential
I cannot Zoom the Tapo C520WS but I can use the Wake, Sleep (Privacy Mode), Pan and Tilt and that is all I need.
Thanks again for sharing.
For anyone interested, there is a stand-alone, python-based module called pytapo
https://github.com/JurajNyiri/pytapo
that also allows you to download the files from a camera's MicroSD card WITHOUT first storing them on the cloud (ie keeping it secure on your premises only). See the sample script in the "Experiments" folder.
Ramblin
Post by Ramblin »
This used to also work on Tapo cameras
- C320WS Hardware V1
- C320WS Hardware V2
- C520WS Hardware V1
Until the last firmware update for Tapo cameras and this module now no longer works.
The pytapo (python) module mentioned above had the same issue but they solved it with a code update adding in another encryption protocol.
I cannot convert the pytapo / python changes into this / perl module but if anyone is good enough at both languages, maybe they could?
You can use the ONVIF solution in Zonminder to control the Tapo pan/tilt cameras but are limited to the ONVIF-supported options.
subir_paul
Post by subir_paul »
I installed the control script for zoneminder from github. But it not working. I am using tapo c200 camera. Hear are my debug log -
5/28/24, 11:59:15 PM GMT+5:30 zmcontrol_1 43444 INF Token expired for https://192.168.0.109:443, retrying : {"method":"do","motor":{"move":{"x_coord":"15","y_coord":"0"}}} zmcontrol.pl -
this shows for every time I try to control.
Peppe1945
Post by Peppe1945 »
tbl
Post by tbl »
Hi all,
I'm new to this forum but I do have the same issue in regards to "Token expired" when trying to PTZ control my new tapo c200.
Firmware version on cam is 1.3.14.
I'm already using the updated (last update 4 days ago) from https://github.com/fabriziopicconi/zoneminder-tapo-c500
In the logs, when activating debug:
11.08.2024 14:03:55.921401 zmcontrol_18[5592].INF [main:116] [Starting control server 18/TapoC200]
11.08.2024 14:03:55.927813 zmcontrol_18[5592].INF [main:127] [Control server 18/TapoC200 starting at 24/08/11 14:03:55]
11.08.2024 14:03:56.378306 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:116] [Tapo C200 Controller opened]
11.08.2024 14:04:18.218324 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Move Con Right]
11.08.2024 14:04:18.221731 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Send command seq:[] for https://<IP>:443/stok=/ds, {"method":"do","motor":{"move":{"x_coord":"10","y_coord":"0"}}}]
11.08.2024 14:04:18.428948 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Token expired for https://<IP>:443, retrying : {"method":"do","motor":{"move":{"x_coord":"10","y_coord":"0"}}}]
11.08.2024 14:04:18.817104 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Send command seq:[] for https://<IP>:443/stok=/ds, {"method":"do","motor":{"move":{"x_coord":"10","y_coord":"0"}}}]
11.08.2024 14:04:19.020423 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Move Con Stop]
11.08.2024 14:04:19.023440 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Send command seq:[1] for https://<IP>:443/stok=/ds, {"method":"do","motor":{"stop":"null"}}]
11.08.2024 14:04:19.213652 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Token expired for https://<IP>:443, retrying : {"method":"do","motor":{"stop":"null"}}]
11.08.2024 14:04:19.591785 zmcontrol_18[5592].INF [ZoneMinder::Control::TapoC200:134] [Send command seq:[] for https://<IP>:443/stok=/ds, {"method":"do","motor":{"stop":"null"}}]
gyzod
Post by gyzod »
I can confirm this repo stills works for latest firmware on a fresh C200. I had to install those 2 packages :
apt install libbytes-random-secure-perl
apt install libcrypt-cbc-perl
The control address port is :443
The credentials is really admin user and your TPlink account password.
pat2
Post by pat2 »
I have 5 Tapo C200 cameras: 4 HW 1.0 + 1 HW2.0. PTZ commands were working through the oparm script.
Today I upgraded the Tapo C200 firmware on all cameras.
Bad idea. damn !!! They are no more working.
I jumped to the forum and I was happy to see there is the solution.
So, I followed the instructions: installed the script in https://github.com/fabriziopicconi/zoneminder-tapo-c500, installed the sw and changed the parameters as per the guide.
After the changes I did, it is not working...I obtain in Zoneminder log:
socket_sendto( /run/zm/zms-790996s.sock ) failed: Connection refused
I'm using admin as user and my TPlink account password on mobile as password.
I'm on Ubuntu 22.04.
Zoneminder 1.36.36
could you help me please ?
probably there are additional library module to be installed like the previous suggested before:
thanks
