Installation
HigherEdVmsAdmin
Installation
Post by HigherEdVmsAdmin »
I tried instructions from https://zoneminder.readthedocs.io/en/st ... 2-bookworm
When I try Step 7: Tweak Apache configuration sudo a2enconf zoneminder, a2enconf is not installed.
Where are the proper install instructions for Debian 12 Bookworm?>
mikb
Re: Installation
Post by mikb »
Sounds like you might be missing some of the apache web server environment.
Is apache installed at all?
I tried a2enconf on this Ubuntu laptop, which has no ZM related stuff on ...
Command 'a2enconf' not found, but can be installed with:
apt install apache2
Seems like it's not a ZM script/binary, but part of apache (which maybe is assumed to be installed already, I haven't looked over the instructions for Debian in detail ... plus apache was already installed and working before I even heard of ZM :D
HigherEdVmsAdmin
Re: Installation
Thanks for reply, The Binaries are there, just not in my path, I guess. That was Debian. I'm going to try Open Mandriva. Getting frustrated with how many changes regarding networking management etc. (No Ifconfig?) HAvent messed with Linux in a few years or decades? :)
mikb
Re: Installation
Post by mikb »
HigherEdVmsAdmin wrote: Tue Jan 28, 2025 2:42 pm Getting frustrated with how many changes regarding networking management etc. (No Ifconfig?) HAvent messed with Linux in a few years or decades? :)
I know the feeling. All the tools that existed and worked need to be deprecated, thrown out, re-written, because "new and different" is better. A lot of the change seems to be change for the sake of change ... I am very happy that Slackware has mostly resisted this silly fashion trend.
Re: Installation
HigherEdVmsAdmin wrote: Tue Jan 28, 2025 12:01 am I tried instructions from https://zoneminder.readthedocs.io/en/st ... 2-bookworm
Here are the good install instructions for Debian 12:
https://wiki.zoneminder.com/Debian_12_B ... and_1.37.x
I run Debian 12. One recommendation is to increase the size of the swap partition. If you already have Debian 12 set up you can add a swap file. I am a bit old school and run a swap equal to or greater than the installed RAM.
mikb
Re: Installation
Post by mikb »
bbunge wrote: Thu Jan 30, 2025 2:42 pm I am a bit old school and run a swap equal to or greater than the installed RAM.
Me too. Not just because I'm old-school, but you suddenly discover that "suspend to DISK" relies on a swap file/partition that is larger than installed RAM.
No swap? No working!
Small swap? Serves you right for following fashion :D ... now go and make a bigger one and try again.
