Event but no identification with ZMES
funix
Post by funix »
I have a problem with ZMES since the upgrade to version 1.36.35, the events are detected but then ZMES does not identify anything to me.
The logs send me this message.
ars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:15 PARENT: checkEvents() new events found=1
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:15 PARENT: There are 1 new Events to process
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:15 PARENT: Forked process:1495816 to handle alarm eid:14414
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:15 |----> FORK:Camera entree (4), eid:14414 Adding event path:/media/motion/events/4/2025-03-0>
mars 01 13:19:15 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:15 |----> FORK:Camera entree (4), eid:14414 Invoking hook on event start:'/var/lib/zmeventnoti>
mars 01 13:19:20 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in index at /usr/bin/zmeventnotification.pl line 3195.
mars 01 13:19:20 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in index at /usr/bin/zmeventnotification.pl line 3197.
mars 01 13:19:22 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in string eq at /usr/bin/zmeventnotification.pl line 3672.
mars 01 13:19:22 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in string eq at /usr/bin/zmeventnotification.pl line 3834.
mars 01 13:19:22 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in string eq at /usr/bin/zmeventnotification.pl line 3935.
mars 01 13:19:26 ultra.kervao.fr zmeventnotification.pl[1495816]: Use of uninitialized value in index at /usr/bin/zmeventnotification.pl line 3197.
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:18 |----> FORK:Camera entree (4), eid:14414 parse of hook: and [] from
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:18 |----> FORK:Camera entree (4), eid:14414 hook start returned with text: json:[] exit:1
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:20 |----> FORK:Camera entree (4), eid:14414 rules: Checking rules for alarm caused by eid:1441>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:20 |----> FORK:Camera entree (4), eid:14414 rules: No rules found for Monitor, allowing:4
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:20 |----> FORK:Camera entree (4), eid:14414 Matching alarm to connection rules...
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:22 |----> FORK:Camera entree (4), eid:14414 For 4 (Camera entree), SHM says: state=1, eid=14414
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: INF:2025-03-01,13:19:22 |----> FORK:Camera entree (4), eid:14414 Event 14414 for Monitor 4 has finished
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:22 |----> FORK:Camera entree (4), eid:14414 Event end object is: state=>pending with cause=>Mo>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: INF:2025-03-01,13:19:24 |----> FORK:Camera entree (4), eid:14414 end hooks/use hooks not being used, going to directl>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-2:2025-03-01,13:19:26 |----> FORK:Camera entree (4), eid:14414 rules: Checking rules for alarm caused by eid:1441>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:26 |----> FORK:Camera entree (4), eid:14414 rules: No rules found for Monitor, allowing:4
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: INF:2025-03-01,13:19:26 |----> FORK:Camera entree (4), eid:14414 Not sending event end alarm, as we did not send a st>
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:30 |----> FORK:Camera entree (4), eid:14414 exiting
mars 01 13:19:30 ultra.kervao.fr zmeventnotification.pl[1495816]: DBG-1:2025-03-01,13:19:30 |----> FORK:Camera entree (4), eid:14414 Ending process:1495816 to handle alarms
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:15 PARENT: ---------->Tick END (active forks:1, total forks:10, active hooks: 0)<--------------
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: ----------> Tick START (active forks:1, total forks:10, active hooks: 0 running for>
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: After tick: TOTAL: 0 ,  ES_CONTROL: 0, FCM+WEB: 0, FCM: 0, WEB: 0, MQTT:0, invalid >
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: RAW TEXT-->update_parallel_hooks--TYPE--add
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: RAW TEXT-->update_parallel_hooks--TYPE--del
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: There are 1 active child forks & 0 zm_detect processes running...
mars 01 13:20:15 ultra.kervao.fr zmeventnotification.pl[1495253]: DBG-2:2025-03-01,13:19:20 PARENT: We've already worked on Monitor:4, Event:14414, not doing anything more
I specify that with version 1.36.33 it worked
_______________________
Blog https://olivier.hoarau.org
Funix https://www.funix.org
Quantum
Re: Event but no identification with ZMES
Post by Quantum »
I'm missing events with v1.36.35 and ZMES.
Last time I tried 1.37 (beta) it didn't work, and I'm afraid to try it again.
funix
Post by funix »
Hello, I'm still with my problem
the debug message of this command
/var/lib/zmeventnotification/bin/zm_detect.py --config /etc/zm/objectconfig.ini --eventid 29103 --monitorid 1 --debug
gives me
04/20/25 18:07:10 zmesdetect_m1[1747988] INF ZMLog.py:292 [Setting up signal handler for logs]
04/20/25 18:07:10 zmesdetect_m1[1747988] INF ZMLog.py:301 [Switching global logger to ZMLog]
04/20/25 18:07:11 zmesdetect_m1[1747988] INF zm_detect.py:283 [---------| app:6.1.29, pyzm:0.3.64, ES:6.1.29
 , OpenCV:4.10.0|------------]
04/20/25 18:07:11 zmesdetect_m1[1747988] INF utils.py:404 [Reading config from: /etc/zm/objectconfig.ini]
04/20/25 18:07:11 zmesdetect_m1[1747988] INF utils.py:409 [Reading secrets from: /etc/zm/secrets.ini]
DBG2 [zmesdetect_m1] [Secret token found in config: !ZM_PORTAL]
DBG2 [zmesdetect_m1] [Secret token found in config: !ZM_USER]
DBG2 [zmesdetect_m1] [Secret token found in config: !ZM_PASSWORD]
DBG2 [zmesdetect_m1] [Secret token found in config: !ZM_API_PORTAL]
DBG2 [zmesdetect_m1] [Secret token found in config: !ML_USER]
DBG2 [zmesdetect_m1] [Secret token found in config: !ML_PASSWORD]
DBG2 [zmesdetect_m1] [Secret token found in config: !PLATEREC_ALPR_KEY]
DBG1 [zmesdetect_m1] [allowing self-signed certs to work...]
DBG2 [zmesdetect_m1] [Now checking for monitor overrides]
DBG3 [zmesdetect_m1] [Finally, doing parameter substitution]
04/20/25 18:07:11 zmesdetect_m1[1747988] INF zm_detect.py:308 [Importing local classes for Object/Face]
04/20/25 18:07:11 zmesdetect_m1[1747988] INF zm_detect.py:333 [Connecting with ZM APIs]
DBG2 [zmesdetect_m1] [Basic auth requested, configuring]
DBG2 [zmesdetect_m1] [API SSL certificate check has been disbled]
DBG1 [zmesdetect_m1] [using username/password for login]
DBG1 [zmesdetect_m1] [{"access_token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNzQ1MTY1MjMyLCJleHAiOjE3NDUxNzI0MzIsInVzZXIiOiJvbGl2aWVyem0iLCJ0eXBlIjoiYWNjZXNzIn0.CNcpvoEZgKyQ5drPhtSnODnEwY7T3_rgSQCon0iFOIk","access_token_expires":7200,"refresh_token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNzQ1MTY1MjMyLCJleHAiOjE3NDUyNTE2MzIsInVzZXIiOiJvbGl2aWVyem0iLCJ0eXBlIjoicmVmcmVzaCJ9.91JFBRXiXJ5vnG_a41XR_JX8rcSAzhWC21CFSq-NFWk","refresh_token_expires":86400,"credentials":"auth=","append_password":0,"version":"1.36.35","apiversion":"2.0"}]
DBG2 [zmesdetect_m1] [Using new token API]
DBG1 [zmesdetect_m1] [Access token expires on:2025-04-20 20:07:12.071587 [7200s]]
DBG1 [zmesdetect_m1] [Refresh token expires on:2025-04-21 18:07:12.072136 [86400s]]
DBG2 [zmesdetect_m1] [using ml_sequence]
DBG2 [zmesdetect_m1] [using stream_sequence]
DBG1 [zmesdetect_m1] [Resetting models, will be loaded on next run]
DBG2 [zmesdetect_m1] [Called detect_stream(stream=29103, ml_overrides={}, options={'frame_strategy': 'most_models', 'frame_set': 'snapshot,alarm', 'contig_frames_before_error': 5, 'max_attempts': 3, 'sleep_between_attempts': 4, 'resize': 800, 'api': <pyzm.api.ZMApi object at 0x7f098d453fd0>, 'polygons': [], 'mid': '1'})]
DBG3 [zmesdetect_m1] [Using automatic locking as we are switching between models]
DBG2 [zmesdetect_m1] [Media get SSL certificate check has been disbled]
DBG2 [zmesdetect_m1] [Using URL 29103 for stream]
DBG2 [zmesdetect_m1] [We will only process frames: ['snapshot', 'alarm']]
DBG2 [zmesdetect_m1] [No need to start streams, we are picking images from https://monserveur.ddns.net/zm/index.php?view=image&eid=29103]
DBG2 [zmesdetect_m1] [in detect_stream() polygons=[]]
DBG3 [zmesdetect_m1] [Reading https://monserveur.ddns.net/zm/index.php?view=image&eid=29103&fid=snapshot]
DBG3 [zmesdetect_m1] [No need to relogin as access token still has 119.99983268333334 minutes remaining]
DBG3 [zmesdetect_m1] [make_request called with url=https://monserveur.ddns.net/zm/index.php?view=image&eid=29103&fid=snapshot payload={} type=get query={'token': 'eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNzQ1MTY1MjMyLCJleHAiOjE3NDUxNzI0MzIsInVzZXIiOiJvbGl2aWVyem0iLCJ0eXBlIjoiYWNjZXNzIn0.CNcpvoEZgKyQ5drPhtSnODnEwY7T3_rgSQCon0iFOIk'}]
DBG2 [zmesdetect_m1] [Raising RELOGIN ValueError]
DBG1 [zmesdetect_m1] [Got ValueError access error: RELOGIN]
DBG1 [zmesdetect_m1] [Retrying login once]
DBG2 [zmesdetect_m1] [Going to use refresh token as it still has 1439.9959097333333 minutes remaining]
DBG1 [zmesdetect_m1] [Using token for login [eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNzQ1MTY1MjMyLCJleHAiOjE3NDUyNTE2MzIsInVzZXIiOiJvbGl2aWVyem0iLCJ0eXBlIjoicmVmcmVzaCJ9.91JFBRXiXJ5vnG_a41XR_JX8rcSAzhWC21CFSq-NFWk]]
DBG1 [zmesdetect_m1] [{"access_token":"eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNzQ1MTY1MjMyLCJleHAiOjE3NDUxNzI0MzIsInVzZXIiOiJvbGl2aWVyem0iLCJ0eXBlIjoiYWNjZXNzIn0.CNcpvoEZgKyQ5drPhtSnODnEwY7T3_rgSQCon0iFOIk","access_token_expires":7200,"credentials":"auth=","append_password":0,"version":"1.36.35","apiversion":"2.0"}]
DBG1 [zmesdetect_m1] [Access token expires on:2025-04-20 20:07:12.364548 [7200s]]
DBG1 [zmesdetect_m1] [Retrying failed request again...]
DBG3 [zmesdetect_m1] [No need to relogin as access token still has 119.99997601666668 minutes remaining]
DBG1 [zmesdetect_m1] [Error reading frame: 1 of max 5 contiguous errors]
DBG3 [zmesdetect_m1] [Reading https://monserveur.ddns.net/zm/index.php?view=image&eid=29103&fid=alarm]
DBG3 [zmesdetect_m1] [No need to relogin as access token still has 119.99681994999999 minutes remaining]
DBG3 [zmesdetect_m1] [make_request called with url=https://monserveur.ddns.net/zm/index.php?view=image&eid=29103&fid=alarm payload={} type=get query={'token': 'eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiJab25lTWluZGVyIiwiaWF0IjoxNzQ1MTY1MjMyLCJleHAiOjE3NDUxNzI0MzIsInVzZXIiOiJvbGl2aWVyem0iLCJ0eXBlIjoiYWNjZXNzIn0.CNcpvoEZgKyQ5drPhtSnODnEwY7T3_rgSQCon0iFOIk'}]
DBG2 [zmesdetect_m1] [Going to use refresh token as it still has 1439.9886447 minutes remaining]
DBG1 [zmesdetect_m1] [Access token expires on:2025-04-20 20:07:12.802778 [7200s]]
DBG3 [zmesdetect_m1] [No need to relogin as access token still has 119.99996825 minutes remaining]
DBG1 [zmesdetect_m1] [Error reading frame: 2 of max 5 contiguous errors]
DBG1 [zmesdetect_m1] [Reached end of frame_set]
DBG1 [zmesdetect_m1] [Ran out of frames to read]
DBG1 [zmesdetect_m1] [perf: TOTAL detection sequence (with image loads) took: 913.25 ms  to process 29103]
DBG1 [zmesdetect_m1] [Closing logs]
It looks like a login problem
funix
Post by funix »
It works by unchecking the opt_use_auth box
Now when detecting I have this error
04/27/25 08:45:39 zmesdetect_m1[2038493] ERR detect_sequence.py:182 [Error loading same model variation for object:No module named 'pycoral.adapters']
but it's a other problem
funix
Post by funix »
Does anyone have the same problem here ?
removing authentication to have zmes working does not please me at all
funix
Post by funix »
I ask my question differently, has anyone managed to get authentication working with ZMES?
