ZM 1.37.61 - ONVIF event messages issues.
Primed73
Re: ZM 1.37.61 - ONVIF event messages issues.
Post by Primed73 »
Did your camera recover in the end?
No, there has been a new firmware released that doesn't work at all, in ZM or ODM.
They have provided a new beta. 1.2.10 build 250120 rel 45083n at least throws no errors. Time will tell if I actually get events.
Yup motion events working again.
Primed73
Post by Primed73 »
ONVIF events still not working at my end:
2/21/25, 12:58:09 PM GMT zmc_m1 3420440 ERR Failed to get ONVIF messages! 8 (null) zm_monitor.cpp 1978
2/21/25, 12:58:07 PM GMT zmc_m1 3420440 INF Triggered off ONVIF zm_monitor.cpp 2004
I recently merged some code that logs the xml if a failure happens.
I've seen tons of those error 8. ALso lots of error 6. Currently everything working well for me though.
Primed73
Post by Primed73 »
Yeah strange, not for me, Gets a motion alarm, doesn't go any further.
2/21/25, 3:34:57 PM GMT zmc_m1 3428379 INF C500: 3400 - Capturing at 14.25 fps, capturing bandwidth 140603bytes/sec Analysing at 1.71 fps zm_monitor.cpp 1934
2/21/25, 3:34:50 PM GMT zmc_m1 3428379 INF C500: 3300 - Capturing at 14.36 fps, capturing bandwidth 124932bytes/sec Analysing at 1.87 fps zm_monitor.cpp 1934
2/21/25, 3:34:43 PM GMT zmc_m1 3428379 INF C500: 3200 - Capturing at 14.24 fps, capturing bandwidth 148576bytes/sec Analysing at 1.71 fps zm_monitor.cpp 1934
2/21/25, 3:34:37 PM GMT zmc_m1 3428456 ERR Failed to get ONVIF messages! 8 (null) zm_monitor.cpp 1978
2/21/25, 3:34:36 PM GMT zmc_m1 3428379 INF C500: 3100 - Capturing at 14.25 fps, capturing bandwidth 120807bytes/sec Analysing at 1.85 fps zm_monitor.cpp 1934
2/21/25, 3:34:34 PM GMT zmc_m1 3428456 INF Setting ClosesEvent zm_monitor.cpp 2008
2/21/25, 3:34:34 PM GMT zmc_m1 3428456 INF Triggered off ONVIF zm_monitor.cpp 2004
2/21/25, 3:34:34 PM GMT zmc_m1 3428456 INF Got Motion Alarm!
Sorry just merged and pushed it.
Primed73
Post by Primed73 »
Excellent, much further this time, it's starting the detection phase, only its staying in alarm state.
2/26/25, 6:52:29 PM GMT zmeventnotification 3532757 INF |----> FORK:C500 (1), eid:173943 Sending event_start notification over FCM
2/26/25, 6:52:28 PM GMT zmc_m1 3532653 ERR Failed to get ONVIF messages! 8 (null)
2/26/25, 6:52:27 PM GMT zmeventnotification 3532757 INF |----> FORK:C500 (1), eid:173943 use hooks/start hook not being used, going to directly send out a notification if checks pass
2/26/25, 6:52:27 PM GMT zmeventnotification 3532630 INF PARENT: New event 173943 reported for Monitor:1 (Name:C500) Continuous[last processed eid:]
2/26/25, 6:52:25 PM GMT zmc_m1 3532655 INF C500: 1820 - Gone into alarm state PreAlarmCount: 0 > AlarmFrameCount:1 Cause:ONVIF
Primed73
Post by Primed73 »
Are the events closing in ONVIF events back to Zoneminder from your C520?
I don't know, havn't been paying attention.
My logs have gotten a lot quieter lately from the ONVIF event detection.... not sure if I've solved it or broken it.
No, the event isn't ending. I recently put some new code in there to handle cameras that don't send close events... but apparently it isn't working.
I get a response of -1 which apparently is EOF. SO I am adding code to kill the alarm if we get EOF. Should help.
Primed73
Post by Primed73 »
Excellent, can you let me know when you have added the updated code?
I'll test on the C500 and give the results.
Many thanks.
