Hello again
I have 3 errors constently poping in LOG since yesterday, the errors started appearing after I did some event searche and I also did some tweeks with the camera resolution (I reverted the changes) so not sure which one triggered the errors, I searched the web for this and did not find anything relevent I also searched the forum with key words like "e6845778" "Unable to seek in stream" "Invalid frame id specified" and "Failed getting a frame" with no luck, I tried to look in other log files for clues and I tried to find the 3 .cpp files with no luck as well, has any one encounter this?
those are the 3 errors:
3/20/25, 8:12:46 AM EDT zms_e6845778 39803 ERR Unable to seek in stream -1 zm_ffmpeg_input.cpp 274
3/20/25, 8:12:41 AM EDT zms_e6845778 39803 ERR Invalid frame id specified. 200 > 200 zm_eventstream.cpp 98
3/20/25, 8:23:46 AM EDT zms_e6845778 42485 ERR Failed getting a frame. zm_eventstream.cpp 849
Server and camera info:
HP Altera Storage Server4120
Intel Xeon Gold 5420+
128 GiB Memory
VMware ESXi 7.0.3
Ubuntu server 24.04
Apache 2.4.58
MySQL 8.0.41
PHP 8.3.6
Zoneminder 1.37
39 cameras in total
most of the cameras are Hikvision
Source type = Ffmpeg
Path = rtsp ://<IP address>:<port>/etc...
resolution set to 1080x720 720p
Top output:
top - 10:57:39 up 2:56, 1 user, load average: 11.50, 13.01, 14.53
Tasks: 741 total, 2 running, 739 sleeping, 0 stopped, 0 zombie
%Cpu(s): 34.5 us, 0.5 sy, 0.0 ni, 64.7 id, 0.0 wa, 0.0 hi, 0.2 si, 0.0 st
MiB Mem : 96647.0 total, 54202.4 free, 26217.2 used, 18022.2 buff/cache
MiB Swap: 24576.0 total, 24576.0 free, 0.0 used. 70429.7 avail Mem
Please let me know if you need more informaton
Thank you
Error zms__e6845778
Re: Error zms__e6845778
Hello
Something changed, now the zms_e6845778 error is gone since last week but I noticed ever since the issue occured I have "out of memory" message on my server and this causes the server to kill the sssd service.
I checked in the Zoneminder logs and noticed a lot of the following:
This zmwatch message started the same date the zms_e6845778 error started, can this give some one a clue?
3/25/25, 4:01:05 AM EDT zmwatch 1957666 WAR daemon for 36 Mobile stationnement Haggerty complet needs restarting, time since last analysis 54 seconds (1742889664-1742889610) zmwatch.pl 186
3/24/25, 11:14:38 PM EDT zmwatch 1957666 WAR daemon for 44 Gate MP3 needs restarting, time since last analysis 68 seconds (1742872478-1742872410) zmwatch.pl 186
3/24/25, 11:14:14 PM EDT zmwatch 1957666 WAR daemon for 40 Stationnement Farrell centre needs restarting, time since last analysis 91 seconds (1742872454-1742872363) zmwatch.pl 186
3/24/25, 11:13:43 PM EDT zmwatch 1957666 WAR daemon for 40 Stationnement Farrell centre needs restarting, time since last analysis 60 seconds (1742872423-1742872363) zmwatch.pl 186
3/24/25, 11:13:42 PM EDT zmwatch 1957666 WAR daemon for 36 Mobile stationnement Haggerty complet needs restarting, time since last analysis 51 seconds (1742872422-1742872371) zmwatch.pl 186
3/24/25, 11:13:25 PM EDT zmwatch 1957666 WAR daemon for 30 Porte 303 Compacteur needs restarting, time since last analysis 80 seconds (1742872405-1742872325) zmwatch.pl 186
3/24/25, 11:12:43 PM EDT zmwatch 1957666 WAR daemon for 29 Quai 3 et 4 needs restarting, time since last analysis 46 seconds (1742872363-1742872317) zmwatch.pl 186
3/24/25, 11:11:03 PM EDT zmwatch 1957666 WAR Restarting capture daemon for 23 Porte Garage 16, no image since startup. Startup time was 0 - now 1742872263 > 45 zmwatch.pl 139
3/24/25, 11:10:52 PM EDT zmwatch 1957666 WAR daemon for 36 Mobile stationnement Haggerty complet needs restarting, time since last analysis 76 seconds (1742872252-1742872176) zmwatch.pl 186
3/24/25, 11:10:36 PM EDT zmwatch 1957666 WAR daemon for 36 Mobile stationnement Haggerty complet needs restarting, time since last analysis 60 seconds (1742872236-1742872176) zmwatch.pl 186
3/24/25, 11:09:23 PM EDT zmwatch 1957666 WAR daemon for 23 Porte Garage 16 needs restarting, time since last analysis 49 seconds (1742872163-1742872114) zmwatch.pl 186
3/24/25, 11:08:27 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Mobile stationnement Haggerty complet, time since last capture 161 seconds (1742872107-1742871946) zmwatch.pl 160
3/24/25, 11:08:13 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Mobile stationnement Haggerty complet, time since last capture 147 seconds (1742872093-1742871946) zmwatch.pl 160
3/24/25, 11:08:06 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Stationnement Haggerty Logistique, time since last capture 49 seconds (1742872086-1742872037) zmwatch.pl 160
3/24/25, 11:07:51 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Mobile stationnement Haggerty complet, time since last capture 125 seconds (1742872071-1742871946) zmwatch.pl 160
3/24/25, 11:07:41 PM EDT zmwatch 1957666 WAR Restarting capture daemon for MP2 Quai 14 et 15, time since last capture 90 seconds (1742872061-1742871971) zmwatch.pl 160
3/24/25, 11:07:05 PM EDT zmwatch 1957666 WAR Restarting capture daemon for 16 Stationnement Haggerty Logistique, no image since startup. Startup time was 1742871937 - now 1742872023 > 45 zmwatch.pl 139
3/24/25, 11:06:58 PM EDT zmwatch 1957666 WAR daemon for 12 Stationnement Haggerty MP1 needs restarting, time since last analysis 56 seconds (1742872014-1742871958) zmwatch.pl 186
3/24/25, 11:01:18 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Stationnement Porte Magasin, time since last capture 102 seconds (1742871678-1742871576) zmwatch.pl 160
3/24/25, 11:00:38 PM EDT zmwatch 1957666 WAR daemon for 11 Stationnement Farrell Porte Principale needs restarting, time since last analysis 90 seconds (1742871638-1742871548) zmwatch.pl 186
3/24/25, 10:56:14 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Stationnement Farrell Entree, time since last capture 50 seconds (1742871374-1742871324) zmwatch.pl 160
3/24/25, 10:53:42 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Vestibule porte principale, time since last capture 859 seconds (1742871222-1742870363) zmwatch.pl 160
3/24/25, 10:52:41 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Gate MP3, time since last capture 91 seconds (1742871133-1742871042) zmwatch.pl 160
3/24/25, 10:50:03 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Portes Exterieur 14 et 15 MP2, time since last capture 95 seconds (1742871003-1742870908) zmwatch.pl 160
3/24/25, 10:49:39 PM EDT zmwatch 1957666 WAR Restarting capture daemon for MP3 Quai 10 a 12, time since last capture 70 seconds (1742870979-1742870909) zmwatch.pl 160
3/24/25, 10:48:29 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Reception Magasin, time since last capture 55 seconds (1742870909-1742870854) zmwatch.pl 160
3/24/25, 10:44:26 PM EDT zmwatch 1957666 WAR daemon for 53 Corridor Arianne - MP3 needs restarting, time since last analysis 65 seconds (1742870666-1742870601) zmwatch.pl 186
3/24/25, 10:44:03 PM EDT zmwatch 1957666 WAR daemon for 51 Sous station 1 needs restarting, time since last analysis 74 seconds (1742870643-1742870569) zmwatch.pl 186
3/24/25, 10:44:00 PM EDT zmwatch 1957666 WAR daemon for 20 PF Quai 23 a 25 needs restarting, time since last analysis 69 seconds (1742870640-1742870571) zmwatch.pl 186
3/24/25, 10:43:57 PM EDT zmwatch 1957666 WAR Restarting capture daemon for PF Quai 20 a 22, time since last capture 47 seconds (1742870635-1742870588) zmwatch.pl 160
3/24/25, 10:41:44 PM EDT zmwatch 1957666 WAR daemon for 49 Sortie stationnement Aggerty needs restarting, time since last analysis 75 seconds (1742870504-1742870429) zmwatch.pl 186
3/24/25, 10:40:09 PM EDT zmwatch 1957666 WAR Restarting capture daemon for PF Quai 17 a 19, time since last capture 99 seconds (1742870409-1742870310) zmwatch.pl 160
3/24/25, 10:39:50 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Stationnement Haggerty MP1, time since last capture 108 seconds (1742870389-1742870281) zmwatch.pl 160
3/24/25, 10:38:30 PM EDT zmwatch 1957666 WAR Restarting capture daemon for Sous-Station Electrique Principale, time since last capture 48 seconds (1742870306-1742870258) zmwatch.pl 160
3/24/25, 4:01:03 AM EDT zmwatch 1890252 WAR daemon for 36 Mobile stationnement Haggerty complet needs restarting, time since last analysis 49 seconds (1742803262-1742803213) zmwatch.pl 186
3/23/25, 10:33:28 PM EDT zmwatch 1611944 WAR daemon for 30 Porte 303 Compacteur needs restarting, time since last analysis 49 seconds (1742783602-1742783553) zmwatch.pl 186
3/23/25, 6:17:21 PM EDT zmwatch 1611944 WAR Restarting capture daemon for 7 Stationnement Farrell Entree, no image since startup. Startup time was 1742768190 - now 1742768241 > 45 zmwatch.pl 139
3/23/25, 10:12:58 AM EDT zmwatch 1611944 WAR Restarting capture daemon for 7 Stationnement Farrell Entree, no image since startup. Startup time was 1742739124 - now 1742739178 > 45 zmwatch.pl 139
3/23/25, 4:01:06 AM EDT zmwatch 1514952 WAR daemon for 35 Portes Exterieur 14 et 15 MP2 needs restarting, time since last analysis 55 seconds (1742716865-1742716810) zmwatch.pl 186
3/22/25, 10:16:39 PM EDT zmwatch 1244702 WAR Restarting capture daemon for Mobile portes Exterieures 17 a 25 PF, time since last capture 52 seconds (1742696195-1742696143) zmwatch.pl 160
3/21/25, 10:04:50 PM EDT zmwatch 427232 WAR Restarting capture daemon for PF Quai 20 a 22, time since last capture 46 seconds (1742609085-1742609039) zmwatch.pl 160
3/21/25, 4:01:06 AM EDT zmwatch 338730 WAR daemon for 21 MP2 Quai 14 et 15 needs restarting, time since last analysis 51 seconds (1742544066-1742544015) zmwatch.pl 186
3/20/25, 11:00:15 PM EDT zmwatch 5222 WAR daemon for 12 Stationnement Haggerty MP1 needs restarting, time since last analysis 136 seconds (1742525998-1742525862) zmwatch.pl 186
3/20/25, 10:51:48 PM EDT zmwatch 5222 WAR Restarting capture daemon for 11 Stationnement Farrell Porte Principale, no image since startup. Startup time was 1742525452 - now 1742525507 > 45 zmwatch.pl 139
3/20/25, 10:51:22 PM EDT zmwatch 5222 WAR Restarting capture daemon for Corridor Arianne - MP3, time since last capture 50 seconds (1742525482-1742525432) zmwatch.pl 160
3/20/25, 10:50:32 PM EDT zmwatch 5222 WAR daemon for 53 Corridor Arianne - MP3 needs restarting, time since last analysis 47 seconds (1742525427-1742525380) zmwatch.pl 186
3/19/25, 10:02:48 PM EDT zmwatch 2676806 WAR Restarting capture daemon for 11 Stationnement Farrell Porte Principale, no image since startup. Startup time was 0 - now 1742436168 > 45 zmwatch.pl 139
3/19/25, 10:02:37 PM EDT zmwatch 2676806 WAR Restarting capture daemon for 11 Stationnement Farrell Porte Principale, no image since startup. Startup time was 0 - now 1742436157 > 45 zmwatch.pl 139
3/19/25, 10:02:25 PM EDT zmwatch 2676806 WAR Restarting capture daemon for 11 Stationnement Farrell Porte Principale, no image since startup. Startup time was 0 - now 1742436144 > 45 zmwatch.pl 139
3/19/25, 10:01:56 PM EDT zmwatch 2676806 WAR Restarting capture daemon for Stationnement Farrell Porte Principale, time since last capture 48 seconds (1742436112-1742436064) zmwatch.pl 160
3/19/25, 4:01:05 AM EDT zmwatch 2594550 WAR daemon for 12 Stationnement Haggerty MP1 needs restarting, time since last analysis 54 seconds (1742371264-1742371210) zmwatch.pl 186
3/18/25, 10:34:00 PM EDT zmwatch 2034148 WAR Restarting capture daemon for Gate MP3, time since last capture 47 seconds (1742351634-1742351587) zmwatch.pl 160
