Only part of frame image is visible when "Enlarge and show .... when a thumbnail is hovered over"
DR_Omi
Post by DR_Omi »
Small inconvenience when looking through alarm frames
/zm/index.php?view=frames&eid=17071744
frames are 720 x 480
image "when a thumbnail is hovered over" is to mach enlarged and it is for this reason cut off on the left to the size of column width.
first image on left side is cut off. When I add "Event id" column, thumbnail in horizontal view is longer.
on second attached file, after clicking on thumbnail the image is fully visible.
DR_Omi
Re: Only part of frame image is visible when "Enlarge and show .... when a thumbnail is hovered over"
Post by DR_Omi »
I get it. It's 5 times bigger then "Options / Web / WEB_LIST_THUMB_WIDTH" . I have decreased it and it's OK.
