migo
Posts: 40 Joined: Tue Oct 11, 2016 9:19 am
Post
by migo » Fri Apr 11, 2025 7:11 am
Hello, I don't see report here, but timeline view is broken for in recent 1.37.x versions. I've got this:
4/11/25, 9:07:20 AM GMT+2.453050 web_js[1286736].ERR [138.95.121.134] [3000ms%20timeout%20exceeded] at ?view=timeline&page=1&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Battr%5D=StartDateTime&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bop%5D=%3E%3D&filter%5BQuery%5D%5Bterms%5D%5B0%5D%5Bval%5D=-1+day&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bcnj%5D=and&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Battr%5D=Monitor&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bop%5D=%3D&filter%5BQuery%5D%5Bterms%5D%5B1%5D%5Bval%5D=11&filter%5BQuery%5D%5Bsort_asc%5D=0&filter%5BQuery%5D%5Bsort_field%5D=StartDateTime line
in web_js.log.
Please take my apology if it is already known issue.
Milan
Screenshot From 2025-04-11 09-02-46.png (179.14 KiB) Viewed 14152 times
IgorA100
Posts: 203 Joined: Sat Feb 03, 2024 11:55 am
Post
by IgorA100 » Fri Apr 11, 2025 8:42 am
Not all content loaded.
What errors are there in the console?
migo
Post
by migo » Fri Apr 11, 2025 9:48 am
Hello, only this:
GET
https://cam.doma23.eu/fonts/material-icons.woff2
[HTTP/1.1 404 Not Found 59ms]
GET
Status
404
Not Found
VersionHTTP/1.1
Transferred498 B (282 B size)
Referrer Policystrict-origin-when-cross-origin
Request PriorityHigh
DNS ResolutionSystem
GET
https://cam.doma23.eu/zm/graphics/transparent.png
[HTTP/1.1 304 Not Modified 71ms]
GET
https://cam.doma23.eu/zm/fonts/fontawesome-webfont.woff2?v=4.7.0
[HTTP/1.1 304 Not Modified 53ms]
No frames skins_classic_views_js_timeline-base-1744300127.js:84:15
XHRGET
https://cam.doma23.eu/zm/index.php?view=request&request=status&entity=frameimage&eid=12992985&fid=1
[HTTP/1.1 200 OK 571ms]
downloadable font: Glyph bbox was incorrect (glyph ids 33 55 62 81 82 83 84 87 88 89 90 112 119 120 123 139 159 162 164 166 178 184 185 217 218 272 273 274 275 279 281 284 290 291 292 309 310 319 321 323 326 329 330 331 332 333 334 339 341 347 349 351 352 353 354 357 358 361 366 367 370 371 414 431 436 444 445 458 460 464 465 483 505 508 511 514 516 517 518 520 521 538 539 546 568 574 579 580 585 586 594 596 599 602 603 616 618 622 627 629 630 633 634 638 643 645 651 654 665 675 685 686 688 691) (font-family: "FontAwesome" style:normal weight:400 stretch:100 src index:1) source: https://cam.doma23.eu/zm/fonts/fontawesome-webfont.woff2?v=4.7.0
GET
[HTTP/1.1 404 Not Found 17ms]
GET
https://cam.doma23.eu/zm/graphics/favicon.ico
[HTTP/1.1 200 OK 0ms]
GET
https://cam.doma23.eu/zm/index.php?view=image&eid=12992985&fid=1
[HTTP/1.1 200 OK 108ms]
XHRPOST
[HTTP/1.1 200 OK 37ms]
XHRGET
https://cam.doma23.eu/zm/index.php?view=request&request=status&entity=navBar&username=admin
[HTTP/1.1 200 OK 67ms]
XHRGET
[HTTP/1.1 200 OK 90ms]
XHRGET
[HTTP/1.1 200 OK 29ms]
XHRGET
[HTTP/1.1 200 OK 128ms]
XHRGET
[HTTP/1.1 200 OK 40ms]
XHRGET
[HTTP/1.1 200 OK 98ms]
XHRGET
[HTTP/1.1 200 OK 42ms]
XHRGET
[HTTP/1.1 200 OK 38ms]
XHRGET
XHRGET
[HTTP/1.1 200 OK 41ms]
XHRGET
[HTTP/1.1 200 OK 30ms]
XHRGET
[HTTP/1.1 200 OK 36ms]
XHRGET
[HTTP/1.1 200 OK 47ms]
XHRGET
XHRGET
XHRGET
XHRGET
[HTTP/1.1 200 OK 48ms]
XHRGET
[HTTP/1.1 200 OK 246ms]
XHRGET
[HTTP/1.1 200 OK 58ms]
XHRGET
[HTTP/1.1 200 OK 54ms]
XHRGET
XHRGET
IgorA100
Post
by IgorA100 » Fri Apr 11, 2025 11:00 am
I found the problem.
I will fix it soon.
Posts: 3356 Joined: Fri Oct 29, 2010 1:43 am
Post
by iconnor » Fri Apr 11, 2025 2:13 pm
PR has been merged, packages building
migo
Post
by migo » Fri Apr 11, 2025 5:52 pm
Thank you very much, issue with missing timeline is solved. But when I hit back button I get only blank screen under menu with repeating message in console, but no error:
XHRGET
https://cam.site.eu/zm/index.php?view=r ... name=admin
Screenshot From 2025-04-11 19-50-57.png (34.06 KiB) Viewed 13425 times
IgorA100
Post
by IgorA100 » Fri Apr 11, 2025 9:06 pm
I'm not sure if this ever worked correctly...
migo
Post
by migo » Sat Apr 12, 2025 5:09 pm
For me it worked ever until last update
IgorA100
Post
by IgorA100 » Sat Apr 12, 2025 5:51 pm
Ok, I'll believe you
Write step by step how I can reproduce the problem, because if I go to "view=events", then click on "Show Timeline", then return to the previous page, then I have no problems.
migo
Post
by migo » Sun Apr 13, 2025 4:13 pm
Ok, you say it works (suspicious), I can confirm it doesn't in Firefox (latest stable) but it works in Chromium, so you have partially right
Steps are exactly like you said, click on some numbers in hour,day or week column of any monitor you get timeline view or events list, hit back and I get blank screen.
Post
by iconnor » Sun Apr 13, 2025 4:36 pm
I don't have this problem either. Not in chrome or firefox.
Maybe is caused by a plugin?
migo
Post
by migo » Sun Apr 13, 2025 4:57 pm
I've only this installed in FF, nothing fancy, I'm on Linux (Arch):
EDIT: Just checked on another Linux machine (Arch too) but Intel platform and older FF (136.0.1) and it is the same for me.
When blank screen is displayed I hit reload and console view is then reloaded correctly.
Screenshot From 2025-04-13 18-55-26.png (75.76 KiB) Viewed 11831 times
IgorA100
Post
by IgorA100 » Sun Apr 13, 2025 5:20 pm
migo wrote: ↑ Sun Apr 13, 2025 4:13 pm
I always get only events list. Then from there I switch to timeline.
Maybe you have some specific settings enabled in ZM?
I just checked again in FF and everything works without problems.
migo
Post
by migo » Sun Apr 13, 2025 6:08 pm
Yes, I've set timeline as default in options:
Screenshot From 2025-04-13 20-07-57.png (152.23 KiB) Viewed 11551 times
