migo wrote: ↑Tue Apr 15, 2025 9:03 am
after that all back actions ends with blank screen
After pressing "Back" for the first time we get to the console, I don't know where and how to press "back" for the second time.
I need step-by-step instructions to reproduce the problem.
I'm sorry for confusion caused. Second time I mean go to the next monitor/or the same and pres back. Than I get blank screen for all subsequent similar actions.
Tested with windows, and I can reproduce this issue on default configured FF in Windows 2022 server. This site was never opened on this system, it was for the first time.
Screenshot From 2025-04-15 14-43-59.png (103.38 KiB) Viewed 16168 times
IgorA100 wrote: ↑Tue Apr 15, 2025 2:42 pm
I don't know what to do yet, because I still can't reproduce the problem
Thank you very much for trying. I can make video/screen recording of this issue, but that will not help to reproduce this issue on your side. There must be some difference in system/language/region that makes this difference.
Maybe someone else will encounter this problem and there will be more information...
Maybe I will be able to reproduce this problem later...
I will try to remember about it...
Thank you, there must be some other factor affecting this issue, because sometime it works and displays console after pressing back and sometime not. Strange...
