Eventserver won`t start
drag.on
Post by drag.on »
Hello everybody,
im fighting with the installation of ES. I got everything working in manual mode but the deamon mode won't start with the Option: OPT_USE_EVENTNOTIFICATION [x]
Now I don't know what to do next. I got no further errors.
ZoneMinder Version: v1.37.66
with best regards
drag.on
Re: Eventserver won`t start
Post by drag.on »
Hello again,
I searched a bit read in the scripts.
I wrote the line: sudo /usr/bin/zmdc.pl startup zmeventnotification.pl
That says , already running. (but, it does not, there is no processing)
[sudo] password for administrator:
perl: warning: Setting locale failed.
perl: warning: Please check that your locale settings:
LANGUAGE = (unset),
LC_ALL = (unset),
LC_TERMINAL = "ShellFish",
LC_CTYPE = "en_US.UTF-8",
LANG = "de_DE.UTF-8"
are supported and installed on your system.
perl: warning: Falling back to a fallback locale ("de_DE.UTF-8").
Already running, ignoring command 'startup'
I executed with "sudo /usr/bin/zmdc.pl restart /usr/bin/zmeventnotification.pl".
sudo /usr/bin/zmdc.pl restart zmeventnotification.pl
LANGUAGE = (unset),
LC_ALL = (unset),
Restarting zmeventnotification.pl
Can't find process with command of 'zmeventnotification.pl'
'zmeventnotification.pl' starting at 25/04/15 14:22:42, pid = 3027
That worked for the session but zmdc.pl does not start this correct by himself and I don't know why.
Why it says can't find process when its works then?
Any ideas?
with best regards
