Hello to everybody,
I'm trying to add the A9 IP mini camera to zoneminder.
I found and installed the P2PCamWin SW Version 1.0.7.5 on my Windows 10 PC and it finds the A9 cam simply typing the UID and password and it works well. Well, I thought:"If p2pcamwin works well, why not zoneminder?"
Because I know the IP address that is assigned to the cam, I tried to analize the traffic from it to my PC (and viceversa) using wireshark and I found that the packets are only on UDP protocol (I didn't find any RTSP or HTTP or any other kind of packets, only the UDP) and the port is 55556.
The problem is that I don't know the right string to fill into the "source" field to add the monitor in zoneminder and VLC player too.
Is there a way to add a monitor into Zoneminder only by UUID and password like the P2PCamWin SW?
If not, how can I add this kind of CAMs?
I don't know the admin user, I think that there isn't; so I tried to insert the source PATH string with and without it, like:
rtsp://admin:password@IP_address:55556 and rtsp://UID_number:password@IP_address:55556
udp://admin:password@IP_address:55556 and udp://UID_number:password@IP_address:55556
or simply
udp://IP_address:55556 and rtsp://IP_address:55556
Of course I tried many kind of sources too...
Is there somebody that can helps me to solve this problem?
Really many thanks in advance
Michele
a9 Mini Camera HD IP
Re: a9 Mini Camera HD IP
I think this thread is the same camera. https://www.domoticz.com/forum/viewtopi ... 35&t=28397
Looks like it phones home and setups the stream with a unique RTSP url each time. The software you referenced is probably their own client that talks to home base. All in all I would run away from that thing.
Hello SteveGilvarry, really many thanks for your reply.SteveGilvarry wrote: ↑Sun Aug 15, 2021 7:42 am I think this thread is the same camera. https://www.domoticz.com/forum/viewtopi ... 35&t=28397
Yes, it is. It is described at the end of that post but I'm not so advanced user to "joke" with Json.
The P2PCamWin SW isn't a dedicated SW. This SW needs only the UID and the password to add the cams. I just downloaded it and tried many SW before to find the right one; at the beginning I could see the CAM only by the Video0 app (for Android).
I bought the A9 CAM because I read that it was an onvif...
Michele
For anyone struggling with this, try installing the app IP Camera Viewer - IPCams for iOS (not sure on android). It detects the camera and the RTSP URL you need for ZM.
I faffed around with Wireshark for hours. This is much simpler.
