Zm 1.37.66 stopped working after update; crash reported on Debian12
busymind
Re: Zm 1.37.66 stopped working after update; crash reported on Debian12
Post by busymind »
the beavers are happy :)
● zoneminder.service - ZoneMinder CCTV recording and surveillance system
Loaded: loaded (/lib/systemd/system/zoneminder.service; enabled; preset: enabled)
Active: active (running) since Wed 2025-02-26 21:51:58 EST; 7s ago
Process: 3790 ExecStart=/usr/bin/zmpkg.pl start (code=exited, status=0/SUCCESS)
Main PID: 3804 (zmdc.pl)
Tasks: 17 (limit: 19136)
Memory: 1.6G
CPU: 12.796s
CGroup: /system.slice/zoneminder.service
├─3804 /usr/bin/perl -wT /usr/bin/zmdc.pl startup
├─3834 /usr/bin/zmc -m 1
├─3839 /usr/bin/zmc -m 2
├─3844 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=2 --daemon
├─3849 /usr/bin/perl -wT /usr/bin/zmfilter.pl --filter_id=4 --daemon
├─3853 /usr/bin/perl -wT /usr/bin/zmwatch.pl
├─3858 /usr/bin/perl -wT /usr/bin/zmupdate.pl -c
├─3865 /usr/bin/perl -wT /usr/bin/zmtelemetry.pl
└─3870 /usr/bin/perl -wT /usr/bin/zmstats.pl
Feb 26 21:51:58 zoneminder sudo[3855]: pam_unix(sudo:session): session opened for user www-data(uid=33) by (uid=0)
Feb 26 21:51:58 zoneminder sudo[3855]: pam_unix(sudo:session): session closed for user www-data
Feb 26 21:51:58 zoneminder sudo[3859]: root : PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl start zmtelemetry.pl
Feb 26 21:51:58 zoneminder sudo[3859]: pam_unix(sudo:session): session opened for user www-data(uid=33) by (uid=0)
Feb 26 21:51:58 zoneminder sudo[3859]: pam_unix(sudo:session): session closed for user www-data
Feb 26 21:51:58 zoneminder sudo[3866]: root : PWD=/usr/share/zoneminder/www ; USER=www-data ; COMMAND=/usr/bin/zmdc.pl start zmstats.pl
Feb 26 21:51:58 zoneminder sudo[3866]: pam_unix(sudo:session): session opened for user www-data(uid=33) by (uid=0)
Feb 26 21:51:58 zoneminder sudo[3866]: pam_unix(sudo:session): session closed for user www-data
Feb 26 21:51:58 zoneminder systemd[1]: Started zoneminder.service - ZoneMinder CCTV recording and surveillance system.
Feb 26 21:51:59 zoneminder zmtelemetry[3865]: WAR [Telemetry server returned HTTP POST error code: 301]
root@zoneminder:~#
klui
Post by klui »
1.37.66~20250227.11-focal fixed the permissions for /etc/zm/*.
Thanks!
gref
Post by gref »
FWIW on Jammy "22.04.5 LTS (Jammy Jellyfish)" this chmod on /etc/zm and /etc/zm/conf.d appears necessary too, this broke suddenly for me.
drag.on
Post by drag.on »
ive got this failure after playing with ONVIF settings. I didn't get it work so disabled the options.
After enabling them again it works and shows using ONVIF.
Best regards
