I did install ZoneMinder on Ubuntu 22.04. All 6 cameraare set to "monitor". One camera did write images to storage location, but was a couple of days ago. No new media content saved. I can view the camera via ZoneMinder. All cameras have the status "' Monitor".
The storage is a mounted 500GB USB external drive. The drive is mounted at "/opt" and I can access the drive using a file mananger. Permissions on the folders and file re fine.as
Does anybody have an idea what is causing this.
Cameras not saving video files
Re: Cameras not saving video files
may I respectfully suggest to go over the installation steps?
There are various places where settings need to be correct for the data to be saved. From config of the storage to permissions. Perhaps you can then narrow down the problem.
