Hello!
I'm running zm on unraid 7, I made a slight mistake when trying to change my date and time setting to be UK GMT time and date format instead of Us local
I'm now met with this error when starting the docker
unable to receive frame : code -1094995529 invalid data found when processing input.
Is there a way to fix this without a fresh install? As I would lose all the events its logged so far
Cheers!
Mistake when changing date and time
Re: Mistake when changing date and time
That is a decoding error, nothing to do with actual time.
Either you are out of CPU or having network issues or your camera is just sending crap.
I'll check the cpu pinning for the docker but it was working fine moments before the time and date changes.
Camera is still running and rstp stream looks fine as well.
