I setup event server with opencv. Event server updates the notes with object detection (person, car, face, etc....) for new events since the setup.
Is there a way to update the notes for all the older events using event server object detection? This way I can delete old false negative events, but keep events that have people in it so I can clear up hard drive space. Thanks.
Object detection for older events?
Re: Object detection for older events?
You can run detect.py --eventid 1234 from a filter....
I'm not a dev and I'm struggling with this.
I took your suggestion and I'm trying to use event filter execute a command on all matches
I tried using
python3 zm_detect.py
but couldn't get that to work. I tried running python3 zm_detect.py on the command line, but got errors about permissions. I think I have to run it as www-data?
Now I'm trying to use zm_event_start.sh. I've used that on the command line with success. I just needed to add --notes TRUE so that it would update the cause description to add person detection.
I'm using %EI% to get the event id, but then it keeps appending the path of the event to the command and that messes things up.
I've been googling, searching for hours, please help.
I tried using
/var/lib/zmeventnotification/bin/zm_event_start.sh 19329459
[ WARN:0@3.411] global net_impl.cpp:178 setUpNet DNN module was not built with CUDA backend; switching to CPU
[s] detected:bowl:91% bird:71% --SPLIT--{"labels": ["bowl", "bird"], "boxes": [[322, 28, 374, 78], [224, 92, 350, 226]], "frame_id": "snapshot", "confidences": [0.9128377437591553, 0.7132459878921509], "image_dimensions": {"original": [1080, 1920], "resized": [450, 800]}}
When running from command line, it doesn't need to be www-data, could be root, so:
sudo /var/lib/zmeventnotification/bin/zm_event_start.sh 19329459
Or if you want to make sure www-data can run it
sudo su -s/bin/bash -c"/var/lib/zmeventnotification/bin/zm_event_start.sh 19329459" www-data
Yeah the path thing is a 1.36 thing... in 1.37 it won't do that.
You could alter your zmfilter.pl to behave like 1.37
line 1062:
my $command = $filter->{AutoExecuteCmd}.' '.$event_path;
$command = substituteTags($command, $filter, $Event);
Make it look like:
my $command = $filter->{AutoExecuteCmd};
if ($command =~ /%\w+%/) {
} else {
$command .= ' '.$Event->Path();
line 1062:
Make it look like:
} else {
