Storage disk replacement - database considerations
cookiemonster
Post by cookiemonster »
Hi.
I had to give up trying to setup motion detection a long time ago. I've been mocord since. I have two cameras mocording on a smallish 2 TB GB drive that gives me only 5 days for the events.
I am awaiting delivery of a new drive. I am OK with losing all events when I replace the disk.
The question is about the zm database and the audit process. I want to avoid both leaving the database in an inconsistent state that forces the audit to spike for a long time until the inconsistencies have been dealt with.
Recreate the database objects? Seems too heavy-handed. I know I can "delete * from events;" but I don't know the db structure so there might be some foreign key constraints on other tables that need taking care of.
So what do people do? What is the recommended approach?
Edit: corrected disk size.
Andyrh
Re: Storage disk replacement - database considerations
Post by Andyrh »
Can you add a disk? If so just point new events at the new disk and wait five days or move the events.
5 days of events should not cause audit to run a long time. How many events is 5 days? In my case 7 days is ~20k events and I have lost all 60 days to a bad RAID controller. Audit cleaned it up in a few hours and did not cause new events to be lost.
I have found ZM to be robust in surviving HDD problems.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
6 cameras -> 54 FPS modect
cookiemonster
thank you for the input. I have just shy of 1600 events in total. Each is about 1.2 GB in size.
I haven't looked yet if I can add the disk but it's possible that I can't and have to replace. Number of SATA ports depending.
However what I want to avoid is the cpu spike. No need to burn electricity if it can be avoided, and it occurs to me that it can. But sure it will only be a few hours I expect but maybe about 2-4.
cookiemonster
The new disk has arrived and the long SMART test will finish tomorrow, when I hope to install it for Zoneminder.
Any other thoughts anyone? Just yank old, put new one in and let audit repair the database? Anything better?
Would be best to add the new drive to the computer then set up ZM to use it leaving the old drive in place. Set a filter to delete the events on the old drive, 100 at a time and when the old drive is empty remove it from ZM, remove the mount from Linux and take the drive out of the computer.
I'm a little bothered by you running zmaudit - it sounds like you may have an underlying problem, or why are you running it?
viewtopic.php?p=115118&hilit=zmaudit+on+1.36#p115118
Andyrh
Post by Andyrh »
I am not sure why you are bothered. I ran an audit when I lost a file system. In this case the OP may plan on loosing a file system with the HDD change. There is not an underlying problem, just a plan to clean the DB. The OP is asking for the best way to change HDDs.
dougmccrary, I think you may have misunderstood the context of the question.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
Might be. But as bbunge and then you said, if hardware possible, just add the new drive and wait (or not) and filter.
So why even worry about the DB, which is on the system drive (most likely)?
Andyrh
Post by Andyrh »
We all suggested just adding a drive. I get the impression that a drive cannot be added, but the existing drive has to be replaced. In that case an audit will clean up the missing events.
I do agree that running an audit should be done sparingly.
Andy
o||||o
Ubuntu 22.04
ZM 1.36.33
E5-1650-v4 Xeon
16 GB RAM
FWIW - I recently was given a Dell Precision Workstation - i7 12 core. I set it up as a new server with the same version of Zoneminder as the old server, used a backup of the old server database and copied the events to the new server. Job done! Only had about 80 GB of events and that took the most time moving it.
Bluemax
Post by Bluemax »
Maybe recreating the database/tables without any events would be a good solution here. Something like a high-level export/import function in zm would be handy. Until then you have to do it manually with mariadb/mysql.
cookiemonster
Thanks for the inputs.
Indeed the context is (was) to replace (not add) a disk, in a methodical manner that would prevent as possible to avoid cpu spikes that would interfere with capture/record and a potential to put the db in an inconsistent state.
I am unable to add the disk in this instance, can only replace.
All is done now. The disk was replaced. The old events were not migrated; a decision I was able to make.
And the audit seems to have settled now without incident. Of course the spike did happen that I would have preferred to avoid but it is what it is.
Thanks again.
