I have installed zone minder and everything seems to work well, but where it exists problem is with the installation of the client of Windows of James Wilson.
I use Windows XP pro, seems to be that the problem is with the service of net 2,0 framework
I cannot install it since it appears to me an error. I have tried of everything, wanted to know that experiences have had and if somebody has solved this.
.net
thanks,
Fausto
Monterrey Mexico
client windows not install !!!
download this from microsoft
http://www.microsoft.com/downloads/info ... tnetfx.exe
then try setup again and you should be good to go
James
James
James Wilson
have you downloaded it?
James Wilson
