jameswilson wrote:ps i thought about timing download speed and keeping this value for future use but i dont always want to downlaod images as fast as possible (stange you may wonder). The main reason for me writing my app was for my use, and when 10 people connect to a server with 25 cams on it and make it refresh as fast as it can, strangly it struggles (at 1 fps that 250 ips never mind what its recording) so i made the option that its only fast when on smaller views.
I think from what you have said the force refresh will fix it on the particular images your having issues with. Am i right in thinking that zm works fine and some other servers but you have a problem with another one?
OK James , No problems. Please don't spend too much time on this for me. I downloaded the latest beta and tried it out. I still had problems with the one cam program over the lan. Yes ZM works fine with it and that is the main goal. The url grab was a freebie <G> I did find one way to crash the program beyond repair and Had to reinstall it. You might want to set a param that will not allow you to enter a (0) ZERO for refresh rate ... I found out it will crash it and it will never reload without crashing after login <G> Leave it to me to really break it <G>
I just could not get the timing to ever work on that one program over the lan. I was trying many different rates but it still stalled. I still have not had the chance to load it here at work, but I did test it on another weather station user that is using Image Salsa and it did work and refershed fine for that one. So I suppose it still is a timing issue just over the lan. I did notice in the viewer the progress bar above the images. It stays full tilt on all my other images including zm images. When I did a remote grab from the other station's image I noticed the image progress bar starting from the left and moving to right as the image loaded and then did an immediate refresh and started over again from the left. No matter the timing I set, Mine over the lan stays full tilt to the right all the time. ( For whatever this is worth.)
I think for me it will work from remote, so please do not spend any more time on it on the url grab my behalf. I plan to eventually move all the cams in to ZM on SME 7.0 Server when it is released. I will then use Image Salsa to grab the images from ZM, which works like a champ and Image Salsa will overlay the images with the weather data.
On the Movie generation, yea it can be a pain with media encoder.
I use another Salsa program that generates an avi from a directory of .jpg images then call a dos batch file with media encoder 8 to make the wmv and delete old avi and actually the same batch file sends it by ftp off site after the generation.
I find the command line of media encoder 8 to work much better then the encoder 9 series, especially in scripting or batch file usage. It is still a pain and I know you are not trying to reproduce zm.
Take care and thanks for all your work!
Dan
