how to uninstall zoneminder - to do a clean install ?
everythins is in the title ...
Regards,
Sophak
Debian stable 2.6.8-4-k7 kernel - logitech pro 4000 X 3 - zoneminder 1.21.3
Learning Php / Mysql / Java /
Sophak
- zoneminder
- Site Admin
- Contact:
Essentially delete everything in your instal bin directory that starts with zm. e.g.
and then remove the web files
and finally drop the database
I think that's all that comes to mind off the top of my head. You will have to change the paths to match your set up however.
Phil
rm /usr/local/bin/zm*
rm -r /var/www/html/zm
rm /var/www/cgi-bin/*zms*
mysql
> drop database zm;
> quit
Phil
- zoneminder
- Site Admin
- Contact:
Actually I've surprised myself as 'make uninstall' should pretty much work, if not then 'make -i uninstall'. The only things left might be zms and nph-zms in /var/www/cgi-bin (or whatever you have defined) and the directories under the zm web directory. You will have to manually delete those for now but Ive put some tweaks in the Makefile for future versions.
The database will still be left however and you will have to manually drop that and any users you may have created etc.
Phil
Phil
- zoneminder
- Site Admin
- Contact:
great comment!!
James Wilson
