odd problem with amount of frames captured...
hi,
i need some help with my new setup...
LIVECD 121.3 fresh install with one camera AXIS 206W
i limited the frame rate both using the camera setup and the config in zoneminder (misc) to 5 frames per second...
that work great...for 12 hours or so...
i check the log (fresh reboot) and it says...
bla bla capturing at 4.5 frames per second
after ~12 hours (nothing changed)
i get
bla bla capturing at 69 frames per second
that of course leads to problem with the ring buffer and i get errors!
and the capture sessions are bad because the frame order is messed up...
any hints or ideas ?
i get
well on ip cam i never limit zm only the cameras itself, i have noticed if there is a slight discrepancy .-2 fps for example all things go mad then the camera may crash, if just limiting the cam all is good for me, on axis 206, 206m and pana blc10
James Wilson
does that mean u have tried or you are going to try?
James Wilson
sorry, i was going to try...
i just check and setting the framrate to 0.00 (zoneminder) worked...
its running for over 12 hours and still working...e.g. only capturing ~4.5 fps and not going beserk...
odd, no idea why that would/could happen if you limit zoneminder and the camera!
strange think ist that i had the same setting on my old install using V121.1 without any problems!
-madmax-
-madmax-
ok,
i tested this more and i'm not sure what i'm doing wrong...
here again the details...
2 setups
Setup 1 (my old system) :
3 AXSIS 206W IP cam's latest firmware (4.21) Maximum FPS set to 5
ZM Live CD install V1.21.1
Buffers set to 40,25,10,0,10,1
setup works great for the last 4 month...
Setup 2 (new system, faster and more HD space)
1 AXSIS 206W IP cam's latest firmware (4.21) Maximum FPS set to 5
the new system we just started works great capturing at around 5 fps like the old system, but afer a couple of hours the new systems start to capture with 50+ fps and then of course shows errors that the ring buffer is to small!
i don't understand because it starts out fine and both systems use the same settings...the only difference is the newer version! and that the new systems is faste etc..
soneone ?
2 setups
soneone ?
and you have max fps on the monitor set to 0 and just using the cam to restrict speed?
From my testing you can only use zm to limit the capture rate if your grabbing jpeg not mjpeg
James Wilson
no the other way round, limit the cam only put zm to max (ie 0)
James Wilson
i have some 206 std and 206m with zm and dont have a problem
but i did when i tried to limit zm
it used to crash the panasonic blc10's i was testing
James Wilson
