How configure realtime fps x storage fps
kenjiu
Post by kenjiu »
I would like if is possible configure to monitoring with realtime fps and save frame like 2 per second. How to configure?
thanks
KenJiu
jameswilson
Post by jameswilson »
use record setting and a frame skip of 23
That way it should
record snapshot, skip 12 frames then snapshot, skip 12, snapshot etc etc
James
James Wilson
kenjiu
Post by kenjiu »
thanks James,
i tried setup bulk (skip) frame rate, but also capture every frame.
now, I configured max_fps to 2 and use tvtime to see in real-time
jameswilson
it would only work in record mode as when in anything else it would ignore the skip rate when in alarm
James Wilson
kenjiu
Post by kenjiu »
work with modetec and mocord?
kenjiu
Post by kenjiu »
... and about montage with 16 cam, why doesn't work? work fine only with 8.
cordel
Post by cordel »
Depends on which browser. in firefox you have to set the network.http.max-persistent-connections-per-server -> to 17 for 16 cameras
This will allow you to view all your cameras.
Frame skip should work in any of the modes and you can uncheck ignore max FPS in your setting so that it respects your max FPS even in alarm.
Regards,
Cordel
