Fedora 4 installation problem
rtk
Post by rtk »
I've a problem to install zm-1.21.4 on Fedora Core 4 :
[root@fedora zm-1.21.4]# ./configure --with-webdir=/var/www/html --with-cgidir=/var/www/cgi-bin
[root@fedora zm-1.21.4]# perl zmconfig.pl
[root@fedora zm-1.21.4]# make
then mv -f ".deps/zm_mpeg.Tpo" ".deps/zm_mpeg.Po"; else rm -f ".deps/zm_mpeg.Tpo"; exit 1; fi
zm_mpeg.cpp: In member function âdouble VideoStream::EncodeFrame(uint8_t*, int, bool, unsigned int)â:
zm_mpeg.cpp:331: error: âstruct AVCodecContextâ has no member named âtime_baseâ
zm_mpeg.cpp:331: error: âav_rescale_qâ was not declared in this scope
make[2]: *** [zm_mpeg.o] Error 1
make[2]: Leaving directory `/root/zm-1.21.4/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/zm-1.21.4'
make: *** [all] Error 2
Help me please ! :)
rtk
Post by rtk »
I've see in this forum a problem is a version of ffmpeg .
I've ffmpeg version 0.4.9-pre1, build 4753
If i try to install cvs version , "make" give me many more error .
Now ... I search on web a possible solution and fortunely I've found a rpm for fedora FC4 :
http://www.lopster.it/zm-1.21.0-306.FC4.i386.rpm
jameswilson
Post by jameswilson »
i dont know as im not a user of fc4 but cordel is working on a fc4 version. That version you have is 1.21.0 we are now on 1.21.4
James Wilson
SyRenity
Post by SyRenity »
Hi.
Just note, that according to my personal experience (from 1.20), anything below the current ZM (1.21.4) doesn't work with Windows Media Player 9 - so it's the best for you to try and get the 1.21.4 running. What errors the make of FFMPEG gives you?
cordel
Post by cordel »
Check and make sure you have removed all files related to the earlier version you had installed. In particular the old library files may need to be removed if they are still present otherwise they will give you grief.
Regards,
Cordel
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
