Zoneminder and Intellinet IP-Camera
I have Problems to view the camera in Zoneminder, no picture is seen in the ZM-Console.
I create a new monitor called Cam1, camera is remote with IP-Adress 192.168.100.221, Port is 8080 and path is 'image.cgi?id=<userid>&password=<password>', the other settings I leave default.
If I click on Cam1 in ZM-Console a new window comes up, but in this window is now picture/stream from the camera.
If I call this adress with my browser, a nice stream is seen :'http://192.168.100.221/image.cgi?id=<us ... ode=applet'
Anyone here can help me?
Zoneminder v1.18.1
Camera : Intellinet Network IP Camera 550710
Page with cgi-examples: http://www.intellinet-network.com/ipcam ... ns-cgi.php
Best regards
Andreas
Zoneminder v1.18.1
Best regards
Andreas
- zoneminder
- Site Admin
- Contact:
Re: Zoneminder and Intellinet IP-Camera
Hi Andreas,
Do you see any errors in /var/log/messages?
Phil,
Phil,
Hi Philip,
I crashed my server :-(
I have to reinstall the complete system and install zoneminder once again. After I finished it, I'll post error-messages (if exists).
Andreas
Andreas
Server is fixed an zoneminder is reinstalled.
Here are the messages from the log-files:
----- /tmp/zmpkg.log -----
Command: start
Executing: su wwwrun --shell=/bin/sh --command='/usr/local/bin/zmdc.pl check'
Removing shared memory
Executing: su wwwrun --shell=/bin/sh --command='/usr/local/bin/zmfix'
Executing: su wwwrun --shell=/bin/sh --command='/usr/local/bin/zmdc.pl status'
Executing: su wwwrun --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmc -m 1'
Executing: su wwwrun --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmfilter.pl -e -1'
Executing: su wwwrun --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y'
Executing: su wwwrun --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmwatch.pl'
----- /var/log/messages -----
----- Port 80 is configured, Remote-Host-Path = image.cgi?id=xxxxxxx&passwd=xxxxxxx
----- I get no stream/picture
Feb 27 14:23:15 linux zmc-m1[4824]: INF [Debug Level = 0, Debug Log = ]
Feb 27 14:23:15 linux zmc-m1[4824]: INF [Got 1 monitors]
Feb 27 14:23:15 linux zmc-m1[4824]: INF [Request: GET image.cgi?id=xxxxxx&passwd=xxxxxxx HTTP/1.1 User-Agent: Zoneminder/1.18.1 Host: 192.168.100.221 Connection: Keep-Alive ]
Feb 27 14:23:15 linux zmc-m1[4824]: INF [monitor purpose=1]
Feb 27 14:23:15 linux zmc-m1[4824]: INF [shm.size=23040448]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Monitor Cam1 has function 2]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Monitor Cam1 LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Monitor Cam1 IBC = 100, WUC = 25, pEC = 10, PEC = 10, FRI = 1000, RBP = 10]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Got 1 zones for monitor Cam1]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Initialised zone 1/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Loaded monitor 1(Cam1), 1 zones]
Feb 27 14:23:16 linux zmc-m1[4824]: INF [Starting Capture]
Feb 27 14:23:16 linux zmc-m1[4824]: ERR [Invalid response status 404: Not Found]
----- Port 8080 is configured, Remote-Host-Path = image.cgi?id=xxxxxxx&passwd=xxxxxxx
----- I get a black picture
Feb 27 14:25:17 linux zms[4885]: INF [Debug Level = 0, Debug Log = ]
Feb 27 14:25:17 linux zms[4885]: INF [Got 1 monitors]
Feb 27 14:25:17 linux zms[4885]: INF [monitor purpose=0]
Feb 27 14:25:17 linux zms[4885]: INF [shm.size=23040448]
Feb 27 14:25:17 linux zms[4885]: INF [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
Feb 27 14:25:17 linux zms[4885]: INF [Monitor Cam1 has function 2]
Feb 27 14:25:17 linux zms[4885]: INF [Monitor Cam1 LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
Feb 27 14:25:17 linux zms[4885]: INF [Monitor Cam1 IBC = 100, WUC = 25, pEC = 10, PEC = 10, FRI = 1000, RBP = 10]
Feb 27 14:25:17 linux zms[4885]: INF [Loaded monitor 1(Cam1), 0 zones]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Debug Level = 0, Debug Log = ]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Got 1 monitors]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Request: GET image.cgi?id=xxxxxxx&passwd=xxxxxxx HTTP/1.1 User-Agent: Zoneminder/1.18.1 Host: 192.168.100.221 Connection: Keep-Alive ]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [monitor purpose=1]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [shm.size=23040448]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Initialised zone 0/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:15, MxAT:0, MnAP:50, MxAP:75000, FB:3x3, MnFP:50, MxFP:50000, MnBS:10, MxBS:0, MnB:0, MxB:0]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Monitor Cam1 has function 2]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Monitor Cam1 LBF = '%%s - %y/%m/%d %H:%M:%S', LBX = 0, LBY = 0]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Monitor Cam1 IBC = 100, WUC = 25, pEC = 10, PEC = 10, FRI = 1000, RBP = 10]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Got 1 zones for monitor Cam1]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Initialised zone 1/All - 1 - 320x240 - Rgb:ff0000, CM:3, MnAT:25, MxAT:0, MnAP:2304, MxAP:57600, FB:3x3, MnFP:2304, MxFP:57600, MnBS:1536, MxBS:0, MnB:1, MxB:0]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Loaded monitor 1(Cam1), 1 zones]
Feb 27 14:25:20 linux zmc-m1[4888]: INF [Starting Capture]
Andreas
Command: start
Andreas
- zoneminder
- Site Admin
- Contact:
Which distro are you using? And can you grep for ERR in any other files in /var/log.
Phil,
Phil,
- zoneminder
- Site Admin
- Contact:
Another thing to try is to force some debug output by sending a USR1 signal to the process when it's running. If you can't do that, edit zmc.cpp and add the line
zm_dbg_level = 3;
under the line that says
zm_dbg_name = ...
Either of these methods should add additional information to the log file.
Phil,
zm_dbg_level = 3;
zm_dbg_name = ...
Phil,
I'm using SuSE 9.0
There are no ERR in /var/log/messages :-(
If I edit zmc.cpp I have to recompile zoneminder - is it right?
Starting 'zmc -m 1' in a shell bring me the errormessage :
linux:/usr/local/bin # ./zmc -m 1
Not a JPEG file: starts with 0x0a 0x0a
This errormessage is also in zmdc.log :
linux:/srv/www/htdocs # tail -f /tmp/zmdc.log
Starting pending process, zmc -m 1
'zmc -m 1' started at 04/02/27 18:35:25
'zmc -m 1' starting at 04/02/27 18:35:25, pid = 4979
'zmc -m 1' crashed at 04/02/27 18:35:25, exit status 1
'zmc -m 1' started at 04/02/27 18:38:05
'zmc -m 1' starting at 04/02/27 18:38:05, pid = 4988
'zmc -m 1' crashed at 04/02/27 18:38:06, exit status 1
Is it possible my IP-Camera is not running with zoneminder?
Is it better to get another camera --> AXIS?
Andreas
Andreas
- zoneminder
- Site Admin
- Contact:
Hi Andreas,
Do you know that the image you are retrieving is a jpg? If you do a wget on the path and save it, can you view it in an image viewer?
Phil
Phil
Hello People,
The camera supports what we refer to as direct image access. It gives you direct access to the internal JPG. This is different to the CGI approach mentioned above. The CGI command returns an HTML page with a JPG embedded, not an actual JPG. That is why it most likely fails.
The direct image access can be configured in the System Configuration of the Camera. By default a username and password is required;
The syntax would be:
If public access is enabled you do not need to provide a username and password:
Here's a live example - reload the page to see the most current image:
http://67.111.35.52/jpg/image.jpg
We assume that ZoneMinder supports this kind of universal syntax.
You can only use this syntax if your camera's Serial Number starts with MNC and if you are running at least Firmware Version 4.0 - but that should be true for most current Network IP Cameras.
I hope this helps.
http://guest:guest@cameraip/jpg/image.jpg
http://cameraip/jpg/image.jpg
I hope this helps.
INTELLINET NETWORK SOLUTIONS
http://www.networkipcamera.com
- zoneminder
- Site Admin
- Contact:
Hi Phil,
That would be great. If you could let us know the results of you test that'd be great.
- zoneminder
- Site Admin
- Contact:
Hi Phil,
Sorry for the late response. I must have missed the email notifcation.
The link is up right now.
Here're a few URLs to choose from:
http://67.111.35.54/jpg/image.jpg
http://62.159.227.166/jpg/image.jpg
In firefox if I select properties I get this error.
Alternate text: The image “http://12.153.66.45/jpg/image.jpg” cannot be displayed, because it contains errors.
I can see a clear differance in the jpeg headers but I don't know what to make of it. There appears to be more information imbeaded in your cameras headers than others.
Phil or some one else will have to take a peek at this as it is beyond me I'm affraid.
Regards,
Cordel
Regards,
Cordel
