Error after Upgrade
nero2k3
Error after Upgrade
Post by nero2k3 »
I have just upgraded from ZM 1.21.0 - 1.21.4 my original version was working fine but after the upgrade i get this message:
java.io.FileNotFoundException
Does anyone have any ideas?
Thanks in advance.
zoneminder
Site Admin
Post by zoneminder »
Where do you get the error? There is no java in ZM at all, though Cambozola uses it if you have that installed.
Phil
zoneminder
Site Admin
By the way, I assume this was a source upgrade?
nero2k3
Error
Post by nero2k3 »
I get the problem when trying to view the camera's
Yes it was a source upgrade.
It also says next to that error:
Server returned HTTP response code 500
I do have Cambozola
Jon
nero2k3
Found something
Post by nero2k3 »
I have just found this in /var/log/messages:
Dec 2 10:35:50 cctvsvr zms[13192]: ERR [Unable to authenticate user]
This happens when i try to view the cameras!!
Jon
jameswilson
Post by jameswilson »
just a though have you looked at the path your client is trying to use. Maybe a switch to plain auth?
James Wilson
nero2k3
Post by nero2k3 »
I tryed that but it made no difference, however i have noticed that i get:
java.io.IOException
Which is different from before!
With the 500 error is it possible that the mysql login is incorrect?
Jon
nero2k3
Post by nero2k3 »
Just to add to that. i checked the messages again:
Dec 2 10:50:28 cctvsvr zms[13675]: ERR [Shared memory not initialised by capture daemon]
Jon
nero2k3
Post by nero2k3 »
Has anyone got any idea on this one? I found a recent post that had what looks like the same problem, they just did the upgrade again, so i tryed that but it is still not working!
Jon
nero2k3
Solved!
Post by nero2k3 »
Right I have finnaly fixed this problem....
It turned out that ZoneMinder was pointing to the /var/www/cgi-bin and so was not picking up the zms in /var/www/html/zm/cgi-bin
Im not sure why it was looking in the wrong place as i have apache setup to point to the ZM cgi-bin
Anyway thanks for the help.
:D
Jon
