Yes, this is what I would like to do. I get the feeling that there is some critical piece of common knowledge that is evading me as nowhere does it mention how to actually get a feed into the server, just how to get one out.SyRenity wrote:Do you mean that you are looking for ways to basically feed video from ZM to a RTP/RTSP streaming server like Helix DNA Server or Darwin Streaming Server? This can be really good, although the CPU requirements should be considered as well.
How much cpu etc it uses remains to be seen. Hopefully it will be less if several feeds are the same monitor going to different people as only one stream will need to be created. It may be more in simple scenarios though. Of course if I ever do get it working it will all be optional!!
I'll take a look at this as well, thanks.SyRenity wrote:BTW, MPEG4IP that was mentioned here, supports RTP/RTSP as well (http://mpeg4ip.sourceforge.net/features/index.php).
By the way I've been running a flash feed for the last hour or so. It's about 10 minutes behind at the moment (though I don't know where all that data is actually stuck). However although my FF went well over 200Mb (which was where it started), the next time I looked it was 175Mb and it's since been 159Mb and is now back to 179Mb. So although it does go up, it's by no means a one way street and periodically large swathes of memory get freed up. I haven't tried with a fresh FF yet though so it may be a flawed test.
Phil
