ctu montage only viewer
martymoose
Post by martymoose »
i have ctu running very nicely indeed
thanks cordel
this is what i need
i have search but have not found
this server box will be a in a remote location in my factory
i want the monitor connected to the ctu box to show the montage only screen 24 hours a day from startup
all other commands will be done for the web page on the other pcs
ie: when booting into ctu the montage will start automaticlly and stay one screen while ever the box is turned on
thanks cordel
keep up the great work
cordel
Post by cordel »
Sorry but at the moment that would not be wise.
Using the browser on the same machine running ZM like that will crash the box. Firefox just don't like running like that for some reason.
It might be possible to go into about:config for firefox and disable all caching and such to eliminate the memory overhead requirements but I have not tested it very throughly. I would suggest getting a quad processor or better and a modulator to accomplish this and just loop the video to both devices. You can then use any TV(s) you want to.
Everyone is looking for an application to be able to do this and it has not yet been developed. We would all like this but thus far if anyone knows how to, they are not sharing :(
Regards,
Corey
martymoose
shoot better change what i did
i changed so user auto logins
then the url to autostart
