ok iam back... phill i send some bug ..
fernando
Post by fernando »
ok first.. this is an old bug. zm uses monitor name to create folder events in disk....... mm ok and example.:
monitor named "new"
events are in /var/www/html/events/new ok
if you change the monitor name you will lost all the events, will be great to use camera Id has event folder.
i have to test it more deeply. but i thing something is wrong with ffmpeg sinse i cant set video atributes has size .. i dont know.
i will write some other things later..
phil what's new in the new release? i cant wait..
ok i found another bug.. i trie to filter on weekdays and i have and error.
this is the url semms ok. is a normal "MonitorId" iqual "1" "and" "Weekday" "equal to" "Monday"
http://192.168.0.10/index.php?view=even ... al2=Monday
i get and error..
this is the web source code.
<p><html><br>
<head><br>
<title>ZM - Eventos</title><br>
<link rel="stylesheet" href="zm_styles.css" type="text/css"><br>
<script language="JavaScript"><br>
function newWindow(Url,Name,Width,Height)<br>
{<br>
var Name = window.open(Url,Name,"resizable,scrollbars,width="+Width+",height="+Height);<br>
}<br>
function eventWindow(Url,Name,Width,Height)<br>
{<br>
var Name = window.open(Url,Name,"resizable,width="+Width+",height="+Height );<br>
}<br>
function filterWindow(Url,Name)<br>
{<br>
var Name = window.open(Url,Name,"resizable,scrollbars,width=560,height=250");<br>
}<br>
function closeWindow()<br>
{<br>
window.close();<br>
// This is a hack. The only way to close an existing window is to try and open it!<br>
var filterWindow = window.open( "/index.php?view=none", 'zmFilter', 'width=1,height=1' );<br>
filterWindow.close();<br>
}<br>
function checkAll(form,name)<br>
{<br>
for (var i = 0; i < form.elements.length; i++)<br>
if (form.elements[i].name.indexOf(name) == 0)<br>
form.elements[i].checked = 1;<br>
form.delete_btn.disabled = false;<br>
}<br>
function configureButton(form,name)<br>
{<br>
var checked = false;<br>
{<br>
if ( form.elements[i].name.indexOf(name) == 0)<br>
{<br>
if ( form.elements[i].checked )<br>
{<br>
checked = true;<br>
break;<br>
}<br>
}<br>
}<br>
form.delete_btn.disabled = !checked;<br>
}<br>
window.focus();<br>
You have an error in your SQL syntax. Check the manual that corresponds to your MySQL server version for the right syntax to use near '2004-03-08 00:00:00' )' )' at line 1</p>
i post all again since i "kill" the other post :) i put some html code.. the forum did't like it. :)
fernando
Re: ok iam back... phill i send some bug ..
Post by fernando »
hi phil iam testing 1.19 and iam getting this same error... do you have it too? or someone?
zoneminder
Site Admin
Post by zoneminder »
Hi Fernando,
Which error are you talking about, the filter one?
Phil,
fernando
Post by fernando »
yes the filter one!! the other one is fixed isnt?
phil.. i consider my self a zm beta tester.. but to follow all the bugs have to be a better way.. some bug, feature trakker or something. what do you think?
fernando
zoneminder
Site Admin
Aaargh, you're right it's broken again. I'll try and find out what happened to it. I suspect I didn't merge in the fix properly.
You're right about the bug tracker. I did used to use Issue-Tracker but that was a bit rubbish and I've since tried to use Request-Tracker which is supposed to be very good. I just can't get it to work on my server though. it has all sorts of apache and perl conflicts and just refuses to start. Whatever I use has to be low maintenance and easy, any suggestions?
Phil,
fernando
Post by fernando »
