Windows Front End for ZM
ok then i will have a play
James Wilson
yes the user name and password is used for both
you need to define the same user name in zm4ms as you use for zm as it passes the login info to zm. ie if you setup a user called stream with a password of stream this also needs to be a user that can stream in zm. Plus at the moment you cant use spaces in user name or password.
Hope that helps
Hope that helps
James Wilson
cool, thankls for the info...
another problem i could use some help is viewing ipcams directly...
i my case i have a axis 206w, but i limited the viewer to a user created on the camera..
usually using a browser i would use this url
user:pw@ip/axis-cgi/jpg/image.cgi?resolution=640x480
using that doesn't work...
if i remove the restricting pn my cam and alow anonymous access using
it works just fine....
any clue howto fix that or is this a bug ?
i presume you have ticked url mode for that cam? if so i dont know why that wont work as in url mode the who
e path s used to request the image, i can only assume a charecter is unliked in the path statement. i will have a look and see.
James Wilson
the : is confusging .net in the path statement, is there another way to pass aurh info without the :
James Wilson
What browser are you using? Be aware that Internet Explorer no longer supports http://user:password@host/path URLS. Give it a try with FireFox or some other browser.-madmax- wrote: another problem i could use some help is viewing ipcams directly...
its not a browser, its a .net picturebox with its url path set to whatever the url is entered (if in url mode)
James Wilson
im not sure what i can do about this as the url thing was never designed for perm viewing of cameras as its designed to get its images from zm. I will look into it but im thinking if .net framework wont pull in an image from a http source with this in it then im tuped, but i will have a look
James Wilson
im sorry i dont understand?
James Wilson
yeah i wrote it, i just didnt get what you mean
James Wilson
