Hi there.
Last week installed this brilliant piece of software. It's really great !
Here are the bugs I had to fix :
in zm_funcs.php ZM_PATH_EVENTS is used but never assigned, so event images are never deleted;
by default RedHat 9 gives no write access to /var/log to user apache;
changing capture image size and restarting the daemons never works. Looks like a problem with getting shared memory. Always have to restart the computer. Or I'm not getting something;
I don't really remember, but AFAIR there was also a problem with saving events images. Something with the paths;
WEB interface is rather slow but maybe it's because of my HDD.
So far I use only one camera on an old Celeron 500 with 192 Mb RAM and CPU usage is usually about 20%. I hope to have more time in a couple of weeks and I'll try to install the suite in our office with 4 or even 8 cameras on a P4. Now I'm measuring uptime with no parameters modifications.
If everything goes well, donations are on the horizon.
Regards,
Igor
