Sitecom Ln-401wireless cam compatibility?
kevoneill
Post by kevoneill »
Hi All.
I am trying to get this camera to work with Zoneminder.
http://www.sitecom.com/drivers_result.p ... ductid=300
Has anybody any experience with these?
They are cheap and nasty cams, but look like suiting my requirements.
Thanks in advance,
Kev
tux
Post by tux »
Hello
The same product is remarked by differents companys ( Soho, Mentor, Bosslan.. and anothers.)
I have one of that (wifi model) bosslan remarket, runs ok but only can obtain 2,5--3 fps, I don´t know is is posible obatim more fps.
You can see here information about this camera.
http://www.zoneminder.com/forums/viewto ... light=soho
If you purchase this camera, write here about your config
kevoneill
Post by kevoneill »
Thanks tux.
that worked a treat.
unclerichy
Post by unclerichy »
What image URL are you using for the camera? I have a camera from the same stable that offers either /IMAGE.CGI or /MJPEG.CGI as the image URL. The latter gives me up to 20fps.
kevoneill
Post by kevoneill »
I was using image.cgi. Thanks for the tip.
tux
Post by tux »
Hi
I don´t know this camera runs with these paths: How you discover these paths (MJPEG/CGI and IMAGE/CGI) ???
I only know this path (/IMAGE.JPG) I discover it becasue if you put camera ip in webrowser and then right button (see image path and time with time format , for example)
http://192.168.100.200/IMAGE.JPG?cidx=2 ... 1291904420
MY OLD CONFIG (only 2.73 fps)
192.168.100.200
/IMAGE.JPG
MY NEW CONFIG (20 fps)
using /MJPEG.CGI
THANKS
unclerichy
tux wrote:Hi
I used an application called Ethereal to capture the traffic going between my PC and the camera when browsing it's web pages. Ethereal can reconstruct the HTML requests and from there the URLs can be grabbed.
tux
Post by tux »
Ok I go to try with ethereal.
thanks
