Another good surveillance GPL app
victor_diago
Post by victor_diago »
http://devsec.sourceforge.net/
It seems to work using mpeg4ip.
I will take a look and see if it have some other interesting features
Thanks Thomas T. Soares. For the tip;
Victor Diago
tux
Post by tux »
nice frontend have this app
jameswilson
Post by jameswilson »
it does
very pretty
....now if i could only find where he got the button grapics from...
James Wilson
cordel
Post by cordel »
The graphics come from KDE :wink:
jameswilson
where in kde? are they png files
James Wilson
cordel
Post by cordel »
Most icon type graphics are in /usr/share/icons/ and are either png or xpm. You need KDEs new ice theme though.
tux
Post by tux »
if you have not installed kde is posible icons are here.
http://kde-look.org/index.php?xcontentmode=22
jameswilson
great thanks
James Wilson
jameswilson
thanks for the above i have found some player icons and added them to the frontend but would love the split screen icons too, dont suppose you know what there called?
James
James Wilson
cordel
Post by cordel »
James, Check your email.
Just make sure you referance where they came from in you about tab.
Corey
jameswilson
ok mate will do i need an about tab then lol. I have got them but only a few are ok cos it only does 16 cams and i need 36. think i will make my own, i suppose i can gimp them can I
James Wilson
maciekc
Post by maciekc »
Does anyone tried it out?
I wanted and it is working but, I didn't see any icons. Does anyone got it working correctly?
jameswilson
your best bet would be the forum for the app, i havnt tried it but i think it looks pretty but not as flexable as zm, im unlikly to try it as it seems mpeg based
James Wilson
