Firefox Ok IE Ko
beuz
Firefox Ok IE Ko
Post by beuz »
Hi
I tried during few days to have the streaming under IE without sucess ,
Stills were ok , but no streaming .
And i decided to have a try with Firefox , and it worked under this
browser !
I m not an experienced user , i have no idea why it doesn t work under
IE.
Can you help ?
beuZ
jameswilson
Post by jameswilson »
i would think its because ie doesnt nativly support mjpeg and requires a java applet called cambozola. ff supports mjpeg nativly so this may be one explantion. If you search here for cambazola you should get some guidance
James Wilson
beuz
Post by beuz »
Thanks for your reply
Well the lastest java is installed , i tried to find an answer on this forum
but again without sucess
Here is a log
zmc_dvideo0[7653]: ERR [Sync failure for frame 0 buffer 0(1):
Interrupted system call]
Perfect under firefox !
Have a nice christmas
BeuZ
jameswilson
the error you posted is from zmzm capture so is affecting capuring not streaming, zms. As you can stream fine in ff, then im pretty sure this is a cambozola issue, if you try to get streams with ie what happens.
James Wilson
beuz
Post by beuz »
:shock: :shock:
I tried with another computer , and it s ok under IE ! I don t understand
what s wrong with my other computer who have exactly the same config
as the one i tried
Anyway thanks for your reply
Rgds
BeuZ
cordel
Post by cordel »
There are a couple things with IE to check. Check your security settings, you may have to add the remote machine to the trusted list. The other thing is the VM on my laptop wouldn't run cambozola, I had to install the JRE for cambozola to work in IE.
I remember being somewhat puzzled at the time as my workstation had worked just fine (XP, upgraded to XPSE, The laptop was installed with XPSE) before I put linux on it.
Regards,
Corey
