Windows Live Viewer..27-11-05 Now Complete Frontend for ZM!!
you can get the file direct from ms or download the official .net 2 and dont click on setup but click on the manifest file instead. It should install and then your away
James Wilson
James,
He may be talking about your link. They would have to grab from
http://217.154.38.122:8080/version2/zm4msbeta.zip Now as you have removed the one from the root and it is under version2/ now. The original posting link is now bad from the 1st. post on this subject.
Dan
Dan
Startup Error
James,
Just downloaded 2.73 beta here at work. I am using .net 2.0 Release so I have to click on the manifest file to install. Installed ok, but as soon as I log in I get the Error: "The property custom1time could not be created fromit's default value.Error Message:24/12/2005 is not a valid value for DateTime.
Course this install is 12/27/2005 US values. Have not seen this one before. But it is not one you can continue and recover from. It just repeats and will not allow you to do anything but quit.
Dan
Dan
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ArgumentException: The property 'custom1time' could not be created from it's default value. Error message: 24/12/2005 is not a valid value for DateTime.
at System.Configuration.SettingsPropertyValue.Deserialize()
at System.Configuration.SettingsPropertyValue.get_PropertyValue()
at System.Configuration.SettingsBase.GetPropertyValueByName(String propertyName)
at System.Configuration.SettingsBase.get_Item(String propertyName)
at System.Configuration.ApplicationSettingsBase.GetPropertyValue(String propertyName)
at System.Configuration.ApplicationSettingsBase.get_Item(String propertyName)
at ViseonViewer2.Settings.get_custom1time()
at ViseonViewer2.MDIParent2.Timer1_Tick(Object sender, EventArgs e)
at System.Windows.Forms.Timer.OnTick(EventArgs e)
at System.Windows.Forms.Timer.TimerNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.26 (RTM.050727-2600)
CodeBase: file:///C:/WINDOWS/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ViseonViewer2
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Downloads/ZoneMinder/viseonviewer2/ViseonViewer2_1_0_0_668/ViseonViewer2.exe
Microsoft.VisualBasic
Assembly Version: 8.0.0.0
Win32 Version: 8.0.50727.26 (RTM.050727-2600)
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/Microsoft.VisualBasic/8.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Runtime.Remoting
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
This appears to be a new error in the beta that has just occured with James last version. I use .net 2.0 beta at home and have not seen this problem. Here at work I use the .net 2.0 release version. I am not sure if this is isolated to the 2.0 release or not.
James will have to have a go at this one. I was using an earlier release on this machine until today and it was not an issue, but I was about 4 betas behind on this machine until today. It looks as though something hardcoded was left int he beta that is not agreeing witht he current datetime variable.
Dan
Dan
ok, looks like a problem, give me 24 hours and i will post a new beta
James Wilson
beta update
I think i have finally removed the need for net 2 beta. I have changed the installer code to automatically get the requirement from ms before install will continue.
Fixed the error with the null refernce on setup. Also fixed the problem regarding custom auto views.
Happy new year
and sorry for the slow response on this one but during the pocket pc development of zm4ppc i broke my visual studio lol
James
Happy new year
James
James Wilson
Now it seems working, there is no more error-message on starting the file.
Next i need a working ZM-Server.
but that's an other Story --> http://www.zoneminder.com/forums/viewtopic.php?t=5438
great thanks for letting me know.
Good luck on getting zm working as my apps pretty useless on its own lol
James Wilson
thats great then no longer do we need the beta framwork.i have also noticed the final .net 2 seems to perform better!
James
James
James Wilson
Can not install Viseon Viewer 2
I just installed the Vision Viewer 2 into my PC running Wn XP PRO.
I downloaded the zip folder and run the setup. The installation procceded and the program get installed on my PC. But when I opened, the user name and password window appeared and I used my DVR user name & password, but I got an error window: "invalid user name or password".
Where can I find the configuration part to input my DVR Server settings.
I will appreciatte your help on this.
Best Regards,
Faustux
Best Regards,
Faustux
