ZM 1.21.4 & 64 bit CPU
Hi!
Is ZM 1.21.4 compatible with CPU AMD 64 bit?
Thanks in advance!
Alessandro
Thanks in advance!
Alessandro
i have one working but in 32 bit mode
James Wilson
I have 64 bit already compiled and up on the ftp if anyone wants it.
http://www.computerntelecom.com/pub/lin ... MS/x86_64/
Regards,
Cordel
Regards,
Cordel
CPU 64 bit
Thanks!
But can I have ZM source file also for CPU 64 bit? I have Slackware 10.2 distribution.
My question is: with current ZM version, (32 bit) can i run it in a CPU 64bit ? Obviously it runs at 32 bit....but it work correctly or crash it?? This is my question....
Thanks in advance!
Alessandro
Thanks in advance!
Alessandro
works fine at the moment ben up for about a week
James
James
James Wilson
Hi.
Runs fine on 64-bit CPU, fedora core 4 64-bit. Check this thread to see the information how to build the ZM on 64-bit:
http://www.zoneminder.com/forums/viewto ... sc&start=0
Fedora 4 64 bit
I followed the intstructions from that link and I still get the same error that it cannot find the libmysqlclient.a file. Is that all you did?SyRenity wrote:Hi.
Hi.
I used the following instructions, and it worked fine for me:
"Version 1.21.3 on Fedora 4 x86_64 kernel, configure kept failing at mysql_init line complaining about no libmysqlclient.a, even with --with-libarch=lib64
I got ./configure working by editing configure and changing /lib/mysql to /lib64/mysql as below:-
MYSQL_LIBS="-L${MYSQL_PREFIX}/lib64/mysql"
and then running
./configure --with-mysql=/usr --with-webdir=/var/www/zm --with-cgidir=/var/www/cgi-bin
or
./configure --with-mysql=/usr --with-webdir=/var/www/zm --with-cgidir=/var/www/cgi-bin --with-ffmpeg=/usr --with-lame=/usr/lib64"
and then running
or
