event auto deletion not working
I setup a filter with automatically delete matches set to true.
this used to delete each event soon after it is collected. But, now with the same filter setting, the events don't auto delete anymore, it just accumulates with time.
what could I be doing wrong?
not sure if it will help and id also look in the filter log but, i had this when i enabled things like ftp and smtp without fully configuring them. this caused the filters to stall and i only noticed cos eventually my disk overflowed as purge whenful wouldnt run.
James Wilson
- zoneminder
- Site Admin
- Contact:
I eliminated all email functions, both from options menu and from filter definition.
there is not much in zmfilter.log except it is scanning for eents.
the filter has two expresssion for selecting 2 monitor ID's, the auto delete box is selected when saved. nothing else!
still the events accumulate and do not auto delete.
if you run that filter do you get any events returned?
James Wilson
Yes we understand that they are accumulating, but if you run the filter, It should return a list of events that it would preform that action on. If it don't return a list of events, it will not do anything.jameswilson wrote:if you run that filter do you get any events returned?
So what happens when you run (click submit) in the filter window?
Corey
so, now I understand what the submit button is for.
right now there are a lot of events piled up. when I click on the All button on one of the camera names, a page with the complete list of events popup. I click show filter window, the filter page pops up. I use the pull down to display the filter which I define as
monitor id equal to 3
monitor id equal to 4
when save, I have "automatically delete all matches" checked.
but when I submit, the page that listed all the events becomes blank, and says 0 events. even though that's the monitor with id=3.
according to you then, the filter is not detecting any of these events. what can be wrong?
what exactly do you want your purge when full filter to do?
James Wilson
Okay so you have two lines, if you would have put you filter settings up this would have gone much faster, on the second line you apperently have the first field set to "and" that should be "or", Change it to or and it will work.
Regards,
Corey
Regards,
Corey
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
that's what it was? how embarrassing.
ok, now when I submit, all the right events come up. and after a while the events do automatically get deleted, as I wanted.
one questions though, the event deletion takes a little delay, event when I manually do submit. is the filter suppose to execute right when I hit "submit" button including the delete event step?
no the filter wont execute it will show the db 'matches' from the info you entered in the query. The filter will run every n seconds. you can change the freq in options under reload filter etc default is 300 seconds i think
james
james
James Wilson
- zoneminder
- Site Admin
- Contact:
