I have been struggling with this for a little over a week now.
After I go thru the perl ./zmconfig.pl and answer all questions successfully, I go on to section 5 in the in the zoneminder readme.
I fail right at the first step "mysql mysql < db/zmschema.sql".
My error is "ERROR 1044 (42000) : Access denied for user ' '@'localhost' to database 'mysql'
I am new to databases so I am guessing that my problem is my command syntax and I do not know any better than to use the commands in the readme verbatim.
Any and all help would make my day (or week)
Problem with database on install
it would appear you have no user name in your sysntax, but i have never built it this way i always use, cordel's and ross's rpm's
Sorry
James
Sorry
James
James Wilson
The reason I thought the mysql database was not there was when typing the command "show databases;" the only database that would show up was test. I did this as admin
Anyhow I did enter the command you suggested as root with the password I set and my error has changed to "ERROR 1050 (42S01) at line 13: Table 'Config' already exists.
Then you may just need to load the database.
This is done with:
perl zmconfig.pl -noi
Regards,
This is done with:
Regards,
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
