Blue Screens, Modprobe.conf
amp
Post by amp »
Is there anyone out there who could assist me setting up my video card? I have tried many modprobe.conf settings per suggestions from the excellant forum and of my own attempts.
My system specs: zm v1.21.4; FC4 (dual boot Win2000)
I have blue screens for my four cameras. The zm / nph-zms servers are running but the caption under each camera reads:
Status: idle .21 fps - (yes, between "."21 - "."55 fps!)
On the zm web interface I have:
Sources - /dev/video0(0); /dev/video1(1);/dev/video2(2);/dev/video3(3);
I have tried various setting within the "options" link.
The video card is a 4 input single chip Conexant Fusion 878A (other markings 25878-13 E349772.1 0316 Taiwan).
It is similar to and has what appears to be the same chip as the one from the post: http://www.zoneminder.com/forums/viewto ... =9936#9936
Also, on the board is a Sunny Sco-060 28.6363Mz 03-04 Crystal Oscillator.
I have read other post regarding this type card but I am not having any luck with setting up my card.
I have tried switching from zms to nph-zms. Those servers do run.
When card=77, the zm log files are good and /var/log/messages do not contain any ERR messages. However there are "open / closed session for root / apache" messages that I do not understand. But the screen remain idle and blue.
I have moved the card to different pci slots.
checked and unchecked Options-Config-ZM_STRICT_VIDEO_CONFIG
check my permissions on files also.
Below are outputs from booting the system without a modprobe.conf file to get a plain "snapshot" of the device.
Any hints, suggestion, pointers are greatly appreciated. Thanks!
Anthony
scanpci -v
pci bus 0x0003 cardnum 0x07 function 0x00: vendor 0x109e device 0x036e
Brooktree Corporation Bt878 Video Capture
STATUS 0x0290 COMMAND 0x0006
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xdfbfe008 addr 0xdfbfe000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0b
pci bus 0x0003 cardnum 0x07 function 0x01: vendor 0x109e device 0x0878
Brooktree Corporation Bt878 Audio Capture
CLASS 0x04 0x80 0x00 REVISION 0x11
BASE0 0xdfbff008 addr 0xdfbff000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0b
[root@aitsurv ~]# /usr/bin/udevinfo -a -p $(udevinfo -q path -n /dev/video0)
udevinfo starts with the device the node belongs to and then walks up the
device chain, to print for every device found, all possibly useful attributes
in the udev key format.
Only attributes within one device section may be used together in one rule,
to match the device for which the node will be created.
device '/sys/class/video4linux/video0' has major:minor 81:0
looking at class device '/sys/class/video4linux/video0':
SUBSYSTEM=="video4linux"
SYSFS{card}=="0"
SYSFS{dev}=="81:0"
SYSFS{name}=="BT878 video _ *** UNKNOWN/GENER"
follow the "device"-link to the physical device:
looking at the device chain at '/sys/devices/pci0000:00/0000:00:1e.0/0000:03:0 7.0':
BUS=="pci"
ID=="0000:03:07.0"
DRIVER=="bttv"
SYSFS{class}=="0x040000"
SYSFS{device}=="0x036e"
SYSFS{irq}=="11"
SYSFS{local_cpus}=="1"
SYSFS{modalias}=="pci:v0000109Ed0000036Esv00000000sd00000000bc04sc00i00"
SYSFS{subsystem_device}=="0x0000"
SYSFS{subsystem_vendor}=="0x0000"
SYSFS{vendor}=="0x109e"
looking at the device chain at '/sys/devices/pci0000:00/0000:00:1e.0':
BUS=="pci"
ID=="0000:00:1e.0"
DRIVER=="unknown"
SYSFS{class}=="0x060400"
SYSFS{device}=="0x244e"
SYSFS{irq}=="0"
SYSFS{modalias}=="pci:v00008086d0000244Esv00000000sd00000000bc06sc04i00"
SYSFS{vendor}=="0x8086"
couldn't open device directory
"Truth is so obscure in these times and falsehood so established that unless you love the truth you will not know it."
Blaise Pascal
zoneminder
Site Admin
Post by zoneminder »
It sounds like it should be working. I would recommend switching all but one monitor off (set Function to None) and then concentrating on that one monitor. If you restart, perhaps you can post what is in your /var/log/messages file?
Phil
cordel
Post by cordel »
I'll have a bit of time in a couple hours to work with you on this if you would like.
Your settings for that card should be:
/dev/video0(0)
/dev/video0(1)
/dev/video0(2)
/dev/video0(3)
and card=77 is correct.
All monitors on that single chip must also match (image size, and color pallet).
This alone might help you out, but if it don't I'll be back a bit later.
Regards,
Corey
amp
Post by amp »
Thanks!
I am going to install my card, and reboot with a modprobe.conf file. I'll start with one monitor also.
Anthony
Blaise Pascal
amp
Post by amp »
Gents,
Here are the log files and modprobe.conf with the card installed:
Looking forward to your assistance.
Anthony
modprobe.conf
alias eth0 8139too
alias snd-card-0 snd-intel8x0
options snd-card-0 index=0
options snd-intel8x0 index=0
remove snd-intel8x0 { /usr/sbin/alsactl store 0 >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-intel8x0
alias usb-controller ehci-hcd
alias usb-controller1 uhci-hcd
#BTTV 4 port card
alias char-major-81 bttv
alias char-major-81-0 bttv
options bttv card=77 radio=0 pll=1 tuner=0
#alias char-major-81-0 bttv
#alias char-major-81-1 bttv
#alias char-major-81-2 bttv
#alias char-major-81-3 bttv
#options bttv card=77 video_nr=0,1,2,3 radio=0 tuner=0
/var/log/messages
Jan 7 19:57:08 aitsurv syslogd 1.4.1: restart.
Jan 7 19:57:08 aitsurv kernel: klogd 1.4.1, log source = /proc/kmsg started.
Jan 7 19:57:08 aitsurv kernel: Linux version 2.6.11-1.1369_FC4 (bhcompile@decompose.build.redhat.com) (gcc version 4.0.0 20050525 (Red Hat 4.0.0-9)) #1 Thu Jun 2 22:55:56 EDT 2005
Jan 7 19:57:08 aitsurv kernel: BIOS-provided physical RAM map:
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 0000000000000000 - 000000000009fc00 (usable)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 000000000009fc00 - 00000000000a0000 (reserved)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 00000000000f0000 - 0000000000100000 (reserved)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 0000000000100000 - 000000000fff0000 (usable)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 000000000fff0000 - 000000000fff8000 (ACPI data)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 000000000fff8000 - 0000000010000000 (ACPI NVS)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 00000000fec00000 - 00000000fec01000 (reserved)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 00000000fee00000 - 00000000fee01000 (reserved)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 00000000ffb00000 - 00000000ffc00000 (reserved)
Jan 7 19:57:08 aitsurv kernel: BIOS-e820: 00000000fff00000 - 0000000100000000 (reserved)
Jan 7 19:57:08 aitsurv kernel: 0MB HIGHMEM available.
Jan 7 19:57:08 aitsurv kernel: 255MB LOWMEM available.
Jan 7 19:57:08 aitsurv kernel: Using x86 segment limits to approximate NX protection
Jan 7 19:57:08 aitsurv kernel: DMI 2.3 present.
Jan 7 19:57:08 aitsurv kernel: ACPI: PM-Timer IO Port: 0x808
Jan 7 19:57:08 aitsurv kernel: Allocating PCI resources starting at 10000000 (gap: 10000000:eec00000)
Jan 7 19:57:08 aitsurv kernel: Built 1 zonelists
Jan 7 19:57:08 aitsurv kernel: Kernel command line: ro root=LABEL=/ rhgb quiet
Jan 7 19:57:08 aitsurv kernel: Initializing CPU#0
Jan 7 19:57:08 aitsurv kernel: CPU 0 irqstacks, hard=c0457000 soft=c0456000
Jan 7 19:57:08 aitsurv kernel: PID hash table entries: 1024 (order: 10, 16384 bytes)
Jan 7 19:57:08 aitsurv kernel: Detected 2418.889 MHz processor.
Jan 7 19:57:08 aitsurv kernel: Using pmtmr for high-res timesource
Jan 7 19:57:08 aitsurv kernel: Console: colour VGA+ 80x25
Jan 7 19:57:08 aitsurv kernel: Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Jan 7 19:57:08 aitsurv kernel: Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
Jan 7 19:57:08 aitsurv kernel: Memory: 254124k/262080k available (2518k kernel code, 7320k reserved, 690k data, 180k init, 0k highmem)
Jan 7 19:57:08 aitsurv kernel: Checking if this processor honours the WP bit even in supervisor mode... Ok.
Jan 7 19:57:08 aitsurv kernel: Security Framework v1.0.0 initialized
Jan 7 19:57:08 aitsurv kernel: SELinux: Initializing.
Jan 7 19:57:08 aitsurv kernel: SELinux: Starting in permissive mode
Jan 7 19:57:08 aitsurv kernel: selinux_register_security: Registering secondary module capability
Jan 7 19:57:08 aitsurv kernel: Capability LSM initialized as secondary
Jan 7 19:57:08 aitsurv kernel: Mount-cache hash table entries: 512
Jan 7 19:57:08 aitsurv kernel: CPU: Trace cache: 12K uops, L1 D cache: 8K
Jan 7 19:57:08 aitsurv kernel: CPU: L2 cache: 128K
Jan 7 19:57:08 aitsurv kernel: Intel machine check architecture supported.
Jan 7 19:57:08 aitsurv kernel: Intel machine check reporting enabled on CPU#0.
Jan 7 19:57:08 aitsurv kernel: CPU0: Intel P4/Xeon Extended MCE MSRs (12) available
Jan 7 19:57:08 aitsurv kernel: CPU: Intel(R) Celeron(R) CPU 2.40GHz stepping 09
Jan 7 19:57:08 aitsurv kernel: Enabling fast FPU save and restore... done.
Jan 7 19:57:08 aitsurv kernel: Enabling unmasked SIMD FPU exception support... done.
Jan 7 19:57:08 aitsurv kernel: Checking 'hlt' instruction... OK.
Jan 7 19:57:08 aitsurv kernel: ACPI: setting ELCR to 0200 (from 0c28)
Jan 7 19:57:08 aitsurv kernel: checking if image is initramfs... it is
Jan 7 19:57:08 aitsurv kernel: Freeing initrd memory: 1081k freed
Jan 7 19:57:08 aitsurv kernel: softlockup thread 0 started up.
Jan 7 19:57:08 aitsurv kernel: NET: Registered protocol family 16
Jan 7 19:57:08 aitsurv kernel: PCI: PCI BIOS revision 2.10 entry at 0xfdb51, last bus=3
Jan 7 19:57:08 aitsurv kernel: PCI: Using configuration type 1
Jan 7 19:57:08 aitsurv kernel: mtrr: v2.0 (20020519)
Jan 7 19:57:08 aitsurv kernel: ACPI: Subsystem revision 20050309
Jan 7 19:57:08 aitsurv kernel: ACPI: Interpreter enabled
Jan 7 19:57:08 aitsurv kernel: ACPI: Using PIC for interrupt routing
Jan 7 19:57:08 aitsurv kernel: ACPI: PCI Root Bridge [PCI0] (0000:00)
Jan 7 19:57:08 aitsurv kernel: PCI: Probing PCI hardware (bus 00)
Jan 7 19:57:08 aitsurv kernel: PCI: Ignoring BAR0-3 of IDE controller 0000:00:1f.1
Jan 7 19:57:08 aitsurv kernel: PCI: Transparent bridge - 0000:00:1e.0
Jan 7 19:57:09 aitsurv kernel: ACPI: Power Resource [URP1] (off)
Jan 7 19:57:09 aitsurv kernel: ACPI: Power Resource [URP2] (off)
Jan 7 19:57:09 aitsurv kernel: ACPI: Power Resource [FDDP] (off)
Jan 7 19:57:09 aitsurv kernel: ACPI: Power Resource [LPTP] (off)
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 7 10 *11 12 14 15)
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Jan 7 19:57:09 aitsurv rpc.statd[1823]: Version 1.0.7 Starting
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 *5 6 7 10 11 12 14 15)
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKD] (IRQs *3 4 5 6 7 10 11 12 14 15)
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 7 10 11 12 14 15) *0, disabled.
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 7 *10 11 12 14 15)
Jan 7 19:57:09 aitsurv kernel: Linux Plug and Play Support v0.97 (c) Adam Belay
Jan 7 19:57:09 aitsurv kernel: pnp: PnP ACPI init
Jan 7 19:57:09 aitsurv kernel: pnp: PnP ACPI: found 11 devices
Jan 7 19:57:09 aitsurv kernel: usbcore: registered new driver usbfs
Jan 7 19:57:09 aitsurv kernel: usbcore: registered new driver hub
Jan 7 19:57:09 aitsurv kernel: PCI: Using ACPI for IRQ routing
Jan 7 19:57:09 aitsurv kernel: PCI: If a device doesn't work, try "pci=routeirq". If it helps, post a report
Jan 7 19:57:09 aitsurv kernel: apm: BIOS not found.
Jan 7 19:57:09 aitsurv kernel: audit: initializing netlink socket (disabled)
Jan 7 19:57:09 aitsurv kernel: audit(1136663769.843:1): initialized
Jan 7 19:57:09 aitsurv kernel: Total HugeTLB memory allocated, 0
Jan 7 19:57:09 aitsurv kernel: VFS: Disk quotas dquot_6.5.1
Jan 7 19:57:09 aitsurv kernel: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
Jan 7 19:57:09 aitsurv kernel: SELinux: Registering netfilter hooks
Jan 7 19:57:09 aitsurv kernel: Initializing Cryptographic API
Jan 7 19:57:09 aitsurv kernel: ksign: Installing public key data
Jan 7 19:57:09 aitsurv kernel: Loading keyring
Jan 7 19:57:09 aitsurv kernel: - Added public key 42BD35A990375F72
Jan 7 19:57:09 aitsurv kernel: - User ID: Red Hat, Inc. (Kernel Module GPG key)
Jan 7 19:57:09 aitsurv kernel: pci_hotplug: PCI Hot Plug PCI Core version: 0.5
Jan 7 19:57:09 aitsurv kernel: ACPI: Processor [CPU1] (supports 8 throttling states)
Jan 7 19:57:09 aitsurv kernel: isapnp: Scanning for PnP cards...
Jan 7 19:57:09 aitsurv kernel: isapnp: No Plug & Play device found
Jan 7 19:57:09 aitsurv kernel: Real Time Clock Driver v1.12
Jan 7 19:57:09 aitsurv kernel: Linux agpgart interface v0.101 (c) Dave Jones
Jan 7 19:57:09 aitsurv kernel: agpgart: Detected an Intel i845 Chipset.
Jan 7 19:57:09 aitsurv kernel: agpgart: AGP aperture is 64M @ 0xe0000000
Jan 7 19:57:09 aitsurv kernel: PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
Jan 7 19:57:09 aitsurv kernel: serio: i8042 AUX port at 0x60,0x64 irq 12
Jan 7 19:57:09 aitsurv kernel: serio: i8042 KBD port at 0x60,0x64 irq 1
Jan 7 19:57:09 aitsurv kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 76 ports, IRQ sharing enabled
Jan 7 19:57:09 aitsurv kernel: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
Jan 7 19:57:09 aitsurv kernel: io scheduler noop registered
Jan 7 19:57:09 aitsurv kernel: io scheduler anticipatory registered
Jan 7 19:57:09 aitsurv kernel: io scheduler deadline registered
Jan 7 19:57:09 aitsurv kernel: io scheduler cfq registered
Jan 7 19:57:09 aitsurv kernel: RAMDISK driver initialized: 16 RAM disks of 16384K size 1024 blocksize
Jan 7 19:57:09 aitsurv kernel: Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
Jan 7 19:57:09 aitsurv kernel: ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
Jan 7 19:57:09 aitsurv kernel: ICH4: IDE controller at PCI slot 0000:00:1f.1
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
Jan 7 19:57:09 aitsurv kernel: PCI: setting IRQ 5 as level-triggered
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:00:1f.1[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Jan 7 19:57:09 aitsurv kernel: ICH4: chipset revision 2
Jan 7 19:57:09 aitsurv kernel: ICH4: not 100% native mode: will probe irqs later
Jan 7 19:57:09 aitsurv kernel: ide0: BM-DMA at 0xfc00-0xfc07, BIOS settings: hda:DMA, hdb:DMA
Jan 7 19:57:09 aitsurv kernel: ide1: BM-DMA at 0xfc08-0xfc0f, BIOS settings: hdc:pio, hdd:pio
Jan 7 19:57:09 aitsurv kernel: hda: WDC WD1200BB-53DWA0, ATA DISK drive
Jan 7 19:57:09 aitsurv kernel: hdb: OPTORITECD-RW CW5201, ATAPI CD/DVD-ROM drive
Jan 7 19:57:09 aitsurv kernel: ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
Jan 7 19:57:09 aitsurv kernel: hda: max request size: 1024KiB
Jan 7 19:57:09 aitsurv kernel: hda: 234441648 sectors (120034 MB) w/2048KiB Cache, CHS=16383/255/63, UDMA(100)
Jan 7 19:57:09 aitsurv kernel: hda: cache flushes supported
Jan 7 19:57:09 aitsurv kernel: hda: hda1 hda2 hda3
Jan 7 19:57:09 aitsurv kernel: hdb: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Jan 7 19:57:09 aitsurv kernel: Uniform CD-ROM driver Revision: 3.20
Jan 7 19:57:09 aitsurv kernel: ide-floppy driver 0.99.newide
Jan 7 19:57:09 aitsurv kernel: usbcore: registered new driver hiddev
Jan 7 19:57:09 aitsurv kernel: usbcore: registered new driver usbhid
Jan 7 19:57:09 aitsurv kernel: drivers/usb/input/hid-core.c: v2.01:USB HID core driver
Jan 7 19:57:09 aitsurv kernel: mice: PS/2 mouse device common for all mice
Jan 7 19:57:09 aitsurv kernel: md: md driver 0.90.1 MAX_MD_DEVS=256, MD_SB_DISKS=27
Jan 7 19:57:09 aitsurv kernel: NET: Registered protocol family 2
Jan 7 19:57:09 aitsurv kernel: IP: routing cache hash table of 512 buckets, 16Kbytes
Jan 7 19:57:09 aitsurv kernel: TCP established hash table entries: 16384 (order: 5, 131072 bytes)
Jan 7 19:57:09 aitsurv kernel: TCP bind hash table entries: 16384 (order: 6, 458752 bytes)
Jan 7 19:57:09 aitsurv kernel: TCP: Hash tables configured (established 16384 bind 16384)
Jan 7 19:57:09 aitsurv kernel: Initializing IPsec netlink socket
Jan 7 19:57:09 aitsurv kernel: NET: Registered protocol family 1
Jan 7 19:57:09 aitsurv kernel: NET: Registered protocol family 17
Jan 7 19:57:09 aitsurv kernel: ACPI wakeup devices:
Jan 7 19:57:09 aitsurv kernel: USB1 USB2 USB3 EHCI ICHB PS2M PS2K UAR1 MC9
Jan 7 19:57:09 aitsurv kernel: ACPI: (supports S0 S1 S3 S4 S5)
Jan 7 19:57:09 aitsurv kernel: Freeing unused kernel memory: 180k freed
Jan 7 19:57:09 aitsurv kernel: input: AT Translated Set 2 keyboard on isa0060/serio0
Jan 7 19:57:09 aitsurv kernel: kjournald starting. Commit interval 5 seconds
Jan 7 19:57:09 aitsurv kernel: EXT3-fs: mounted filesystem with ordered data mode.
Jan 7 19:57:09 aitsurv kernel: input: ImPS/2 Generic Wheel Mouse on isa0060/serio1
Jan 7 19:57:09 aitsurv kernel: SELinux: Disabled at runtime.
Jan 7 19:57:09 aitsurv kernel: SELinux: Unregistering netfilter hooks
Jan 7 19:57:09 aitsurv kernel: Floppy drive(s): fd0 is 1.44M
Jan 7 19:57:09 aitsurv kernel: FDC 0 is a post-1991 82077
Jan 7 19:57:09 aitsurv kernel: 8139too Fast Ethernet driver 0.9.27
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 5
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:03:0a.0[A] -> Link [LNKB] -> GSI 5 (level, low) -> IRQ 5
Jan 7 19:57:09 aitsurv kernel: eth0: RealTek RTL8139 at 0xcc00, 00:0b:6a:24:32:2e, IRQ 5
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:00:1f.5 -> Link [LNKB] -> GSI 5 (level, low) -> IRQ 5
Jan 7 19:57:09 aitsurv kernel: intel8x0_measure_ac97_clock: measured 49480 usecs
Jan 7 19:57:09 aitsurv kernel: intel8x0: clocking to 48000
Jan 7 19:57:09 aitsurv kernel: hw_random: RNG not detected
Jan 7 19:57:09 aitsurv kernel: shpchp: shpc_init : shpc_cap_offset == 0
Jan 7 19:57:09 aitsurv kernel: shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Jan 7 19:57:09 aitsurv kernel: Linux video capture interface: v1.00
Jan 7 19:57:09 aitsurv kernel: bttv: driver version 0.9.15 loaded
Jan 7 19:57:09 aitsurv kernel: bttv: using 8 buffers with 2080k (520 pages) each for capture
Jan 7 19:57:09 aitsurv kernel: bttv: Bt8xx card found (0).
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:03:05.0[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Jan 7 19:57:09 aitsurv kernel: bttv0: Bt878 (rev 17) at 0000:03:05.0, irq: 5, latency: 32, mmio: 0xdfbfe000
Jan 7 19:57:09 aitsurv kernel: bttv0: using: GrandTec Multi Capture Card (Bt878) [card=77,insmod option]
Jan 7 19:57:09 aitsurv kernel: bttv0: using tuner=0
Jan 7 19:57:09 aitsurv kernel: bttv0: i2c: checking for TDA9875 @ 0xb0... not found
Jan 7 19:57:09 aitsurv kernel: bttv0: i2c: checking for TDA7432 @ 0x8a... not found
Jan 7 19:57:09 aitsurv kernel: bttv0: i2c: checking for TDA9887 @ 0x86... not found
Jan 7 19:57:09 aitsurv kernel: bttv0: registered device video0
Jan 7 19:57:09 aitsurv kernel: bttv0: registered device vbi0
Jan 7 19:57:09 aitsurv kernel: bttv0: PLL: 28636363 => 35468950 .. ok
Jan 7 19:57:09 aitsurv kernel: bt878: AUDIO driver version 0.0.0 loaded
Jan 7 19:57:09 aitsurv kernel: bt878: Bt878 AUDIO function found (0).
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:03:05.1[A] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Jan 7 19:57:09 aitsurv kernel: bt878(0): Bt878 (rev 17) at 03:05.1, irq: 5, latency: 32, memory: 0xdfbff000
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKH] enabled at IRQ 10
Jan 7 19:57:09 aitsurv kernel: PCI: setting IRQ 10 as level-triggered
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:00:1d.7[D] -> Link [LNKH] -> GSI 10 (level, low) -> IRQ 10
Jan 7 19:57:09 aitsurv kernel: ehci_hcd 0000:00:1d.7: EHCI Host Controller
Jan 7 19:57:09 aitsurv kernel: ehci_hcd 0000:00:1d.7: debug port 1
Jan 7 19:57:09 aitsurv kernel: ehci_hcd 0000:00:1d.7: new USB bus registered, assigned bus number 1
Jan 7 19:57:09 aitsurv kernel: ehci_hcd 0000:00:1d.7: irq 10, io mem 0xdffffc00
Jan 7 19:57:09 aitsurv kernel: ehci_hcd 0000:00:1d.7: USB 2.0 initialized, EHCI 1.00, driver 10 Dec 2004
Jan 7 19:57:09 aitsurv kernel: hub 1-0:1.0: USB hub found
Jan 7 19:57:09 aitsurv kernel: hub 1-0:1.0: 6 ports detected
Jan 7 19:57:09 aitsurv kernel: USB Universal Host Controller Interface driver v2.2
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 11
Jan 7 19:57:09 aitsurv kernel: PCI: setting IRQ 11 as level-triggered
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:00:1d.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.0: UHCI Host Controller
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.0: new USB bus registered, assigned bus number 2
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.0: irq 11, io base 0x0000e400
Jan 7 19:57:09 aitsurv kernel: hub 2-0:1.0: USB hub found
Jan 7 19:57:09 aitsurv kernel: hub 2-0:1.0: 2 ports detected
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 3
Jan 7 19:57:09 aitsurv kernel: PCI: setting IRQ 3 as level-triggered
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:00:1d.1 -> Link [LNKD] -> GSI 3 (level, low) -> IRQ 3
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.1: UHCI Host Controller
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.1: new USB bus registered, assigned bus number 3
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.1: irq 3, io base 0x0000e800
Jan 7 19:57:09 aitsurv kernel: hub 3-0:1.0: USB hub found
Jan 7 19:57:09 aitsurv kernel: hub 3-0:1.0: 2 ports detected
Jan 7 19:57:09 aitsurv kernel: ACPI: PCI Interrupt 0000:00:1d.2[C] -> Link [LNKC] -> GSI 5 (level, low) -> IRQ 5
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.2: UHCI Host Controller
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.2: new USB bus registered, assigned bus number 4
Jan 7 19:57:09 aitsurv kernel: uhci_hcd 0000:00:1d.2: irq 5, io base 0x0000ec00
Jan 7 19:57:09 aitsurv kernel: hub 4-0:1.0: USB hub found
Jan 7 19:57:09 aitsurv kernel: hub 4-0:1.0: 2 ports detected
Jan 7 19:57:09 aitsurv kernel: NET: Registered protocol family 10
Jan 7 19:57:09 aitsurv kernel: Disabled Privacy Extensions on device c03e6820(lo)
Jan 7 19:57:09 aitsurv kernel: IPv6 over IPv4 tunneling driver
Jan 7 19:57:09 aitsurv kernel: ACPI: Power Button (FF) [PWRF]
Jan 7 19:57:09 aitsurv kernel: ibm_acpi: ec object not found
Jan 7 19:57:09 aitsurv kernel: md: Autodetecting RAID arrays.
Jan 7 19:57:09 aitsurv kernel: md: autorun ...
Jan 7 19:57:09 aitsurv kernel: md: ... autorun DONE.
Jan 7 19:57:09 aitsurv kernel: device-mapper: 4.4.0-ioctl (2005-01-12) initialised: dm-devel@redhat.com
Jan 7 19:57:09 aitsurv kernel: EXT3 FS on hda2, internal journal
Jan 7 19:57:09 aitsurv kernel: Adding 1052248k swap on /dev/hda3. Priority:-1 extents:1
Jan 7 19:57:09 aitsurv kernel: ip_tables: (C) 2000-2002 Netfilter core team
Jan 7 19:57:09 aitsurv kernel: ip_conntrack version 2.1 (2047 buckets, 16376 max) - 272 bytes per conntrack
Jan 7 19:57:09 aitsurv kernel: eth0: link up, 100Mbps, full-duplex, lpa 0x45E1
Jan 7 19:57:09 aitsurv auditd[1837]: Init complete, audit pid set to: 1837
Jan 7 19:57:13 aitsurv kernel: parport: PnPBIOS parport detected.
Jan 7 19:57:13 aitsurv kernel: parport0: PC-style at 0x378 (0x778), irq 7 [PCSPP,TRISTATE,EPP]
Jan 7 19:57:14 aitsurv kernel: lp0: using parport0 (interrupt-driven).
Jan 7 19:57:14 aitsurv kernel: lp0: console ready
Jan 7 19:57:14 aitsurv udev[2148]: udev_rules.c: configured rule in '/etc/udev/rules.d/50-udev.rules[169]' applied, added symlink 'par%n'
Jan 7 19:57:14 aitsurv udev[2148]: udev_rules.c: add symlink 'par0'
Jan 7 19:57:14 aitsurv udev[2148]: udev_rules.c: no rule found, use kernel name 'lp0'
Jan 7 19:57:14 aitsurv udev[2148]: udev_add.c: creating device node '/dev/lp0'
Jan 7 19:57:14 aitsurv udev[2148]: udev_add.c: preserve file '/dev/lp0', cause it has correct dev_t
Jan 7 19:57:15 aitsurv xinetd[2180]: xinetd Version 2.3.13 started with libwrap loadavg options compiled in.
Jan 7 19:57:15 aitsurv xinetd[2180]: Started working: 0 available services
Jan 7 19:57:17 aitsurv gpm[2319]: *** info [startup.c(95)]:
Jan 7 19:57:17 aitsurv gpm[2319]: Started gpm successfully. Entered daemon mode.
Jan 7 19:57:17 aitsurv gpm[2319]: *** info [mice.c(1766)]:
Jan 7 19:57:17 aitsurv gpm[2319]: imps2: Auto-detected intellimouse PS/2
Jan 7 19:57:23 aitsurv fstab-sync[2414]: removed all generated mount points
Jan 7 19:57:24 aitsurv fstab-sync[2423]: added mount point /media/floppy for /dev/fd0
Jan 7 19:57:24 aitsurv fstab-sync[2426]: added mount point /media/cdrecorder for /dev/hdb
Jan 7 19:57:25 aitsurv su(pam_unix)[2445]: session opened for user apache by (uid=0)
Jan 7 19:57:26 aitsurv su(pam_unix)[2445]: session closed for user apache
Jan 7 19:57:27 aitsurv su(pam_unix)[2451]: session opened for user apache by (uid=0)
Jan 7 19:57:28 aitsurv su(pam_unix)[2451]: session closed for user apache
Jan 7 19:57:29 aitsurv su(pam_unix)[2454]: session opened for user apache by (uid=0)
Jan 7 19:57:33 aitsurv su(pam_unix)[2454]: session closed for user apache
Jan 7 19:57:34 aitsurv su(pam_unix)[2480]: session opened for user apache by (uid=0)
Jan 7 19:57:34 aitsurv su(pam_unix)[2480]: session closed for user apache
Jan 7 19:57:34 aitsurv zmc_dvideo0[2483]: INF [Debug Level = 0, Debug Log = <none>]
Jan 7 19:57:35 aitsurv zmc_dvideo0[2483]: INF [Starting Capture]
Jan 7 19:57:35 aitsurv su(pam_unix)[2485]: session opened for user apache by (uid=0)
Jan 7 19:57:36 aitsurv su(pam_unix)[2485]: session closed for user apache
Jan 7 19:57:37 aitsurv su(pam_unix)[2490]: session opened for user apache by (uid=0)
Jan 7 19:57:38 aitsurv su(pam_unix)[2490]: session closed for user apache
Jan 7 19:57:39 aitsurv su(pam_unix)[2496]: session opened for user apache by (uid=0)
Jan 7 19:57:39 aitsurv su(pam_unix)[2496]: session closed for user apache
Jan 7 19:57:40 aitsurv udev[2514]: udev_rules.c: no rule found, use kernel name 'vcs1'
Jan 7 19:57:40 aitsurv udev[2514]: udev_add.c: creating device node '/dev/vcs1'
Jan 7 19:57:40 aitsurv udev[2516]: udev_rules.c: no rule found, use kernel name 'vcs2'
Jan 7 19:57:40 aitsurv udev[2516]: udev_add.c: creating device node '/dev/vcs2'
Jan 7 19:57:40 aitsurv udev[2518]: udev_rules.c: no rule found, use kernel name 'vcsa1'
Jan 7 19:57:40 aitsurv udev[2518]: udev_add.c: creating device node '/dev/vcsa1'
Jan 7 19:57:40 aitsurv udev[2521]: udev_rules.c: no rule found, use kernel name 'vcsa2'
Jan 7 19:57:40 aitsurv udev[2521]: udev_add.c: creating device node '/dev/vcsa2'
Jan 7 19:57:40 aitsurv udev[2533]: udev_remove.c: removing device node '/dev/vcsa1'
Jan 7 19:57:40 aitsurv udev[2536]: udev_remove.c: removing device node '/dev/vcs1'
Jan 7 19:57:40 aitsurv udev[2539]: udev_rules.c: no rule found, use kernel name 'vcs4'
Jan 7 19:57:40 aitsurv udev[2539]: udev_add.c: creating device node '/dev/vcs4'
Jan 7 19:57:40 aitsurv udev[2541]: udev_rules.c: no rule found, use kernel name 'vcs6'
Jan 7 19:57:40 aitsurv udev[2541]: udev_add.c: creating device node '/dev/vcs6'
Jan 7 19:57:40 aitsurv udev[2547]: udev_rules.c: no rule found, use kernel name 'vcsa4'
Jan 7 19:57:40 aitsurv udev[2547]: udev_add.c: creating device node '/dev/vcsa4'
Jan 7 19:57:40 aitsurv udev[2550]: udev_rules.c: no rule found, use kernel name 'vcsa6'
Jan 7 19:57:40 aitsurv udev[2550]: udev_add.c: creating device node '/dev/vcsa6'
Jan 7 19:57:40 aitsurv udev[2556]: udev_remove.c: removing device node '/dev/vcs2'
Jan 7 19:57:40 aitsurv udev[2560]: udev_rules.c: no rule found, use kernel name 'vcs3'
Jan 7 19:57:40 aitsurv udev[2560]: udev_add.c: creating device node '/dev/vcs3'
Jan 7 19:57:40 aitsurv udev[2563]: udev_rules.c: no rule found, use kernel name 'vcs1'
Jan 7 19:57:40 aitsurv udev[2563]: udev_add.c: creating device node '/dev/vcs1'
Jan 7 19:57:40 aitsurv udev[2564]: udev_rules.c: no rule found, use kernel name 'vcsa1'
Jan 7 19:57:40 aitsurv udev[2564]: udev_add.c: creating device node '/dev/vcsa1'
Jan 7 19:57:40 aitsurv udev[2570]: udev_rules.c: no rule found, use kernel name 'vcs5'
Jan 7 19:57:40 aitsurv udev[2570]: udev_add.c: creating device node '/dev/vcs5'
Jan 7 19:57:40 aitsurv udev[2577]: udev_rules.c: no rule found, use kernel name 'vcs2'
Jan 7 19:57:40 aitsurv udev[2577]: udev_add.c: creating device node '/dev/vcs2'
Jan 7 19:57:40 aitsurv udev[2579]: udev_rules.c: no rule found, use kernel name 'vcsa3'
Jan 7 19:57:40 aitsurv udev[2579]: udev_add.c: creating device node '/dev/vcsa3'
Jan 7 19:57:40 aitsurv udev[2592]: udev_remove.c: removing device node '/dev/vcs4'
Jan 7 19:57:40 aitsurv udev[2594]: udev_rules.c: no rule found, use kernel name 'vcsa5'
Jan 7 19:57:40 aitsurv udev[2599]: udev_remove.c: removing device node '/dev/vcsa4'
Jan 7 19:57:40 aitsurv udev[2605]: udev_remove.c: removing device node '/dev/vcs6'
Jan 7 19:57:40 aitsurv udev[2608]: udev_remove.c: removing device node '/dev/vcsa6'
Jan 7 19:57:40 aitsurv udev[2615]: udev_rules.c: no rule found, use kernel name 'vcs4'
Jan 7 19:57:40 aitsurv udev[2618]: udev_remove.c: removing device node '/dev/vcs3'
Jan 7 19:57:40 aitsurv udev[2621]: udev_remove.c: removing device node '/dev/vcsa3'
Jan 7 19:57:40 aitsurv udev[2624]: udev_remove.c: removing device node '/dev/vcs5'
Jan 7 19:57:40 aitsurv udev[2594]: udev_add.c: creating device node '/dev/vcsa5'
Jan 7 19:57:40 aitsurv udev[2634]: udev_rules.c: no rule found, use kernel name 'vcsa4'
Jan 7 19:57:40 aitsurv udev[2638]: udev_rules.c: no rule found, use kernel name 'vcs6'
Jan 7 19:57:40 aitsurv udev[2639]: udev_remove.c: removing device node '/dev/vcsa2'
Jan 7 19:57:40 aitsurv udev[2643]: udev_rules.c: no rule found, use kernel name 'vcsa6'
Jan 7 19:57:40 aitsurv udev[2615]: udev_add.c: creating device node '/dev/vcs4'
Jan 7 19:57:41 aitsurv udev[2648]: udev_rules.c: no rule found, use kernel name 'vcs3'
Jan 7 19:57:41 aitsurv udev[2634]: udev_add.c: creating device node '/dev/vcsa4'
Jan 7 19:57:41 aitsurv udev[2638]: udev_add.c: creating device node '/dev/vcs6'
Jan 7 19:57:41 aitsurv udev[2643]: udev_add.c: creating device node '/dev/vcsa6'
Jan 7 19:57:41 aitsurv udev[2654]: udev_rules.c: no rule found, use kernel name 'vcsa3'
Jan 7 19:57:41 aitsurv udev[2648]: udev_add.c: creating device node '/dev/vcs3'
Jan 7 19:57:41 aitsurv udev[2658]: udev_rules.c: no rule found, use kernel name 'vcs5'
Jan 7 19:57:41 aitsurv udev[2662]: udev_remove.c: removing device node '/dev/vcsa5'
Jan 7 19:57:41 aitsurv udev[2666]: udev_rules.c: no rule found, use kernel name 'vcsa2'
Jan 7 19:57:41 aitsurv udev[2654]: udev_add.c: creating device node '/dev/vcsa3'
Jan 7 19:57:41 aitsurv udev[2658]: udev_add.c: creating device node '/dev/vcs5'
Jan 7 19:57:41 aitsurv udev[2666]: udev_add.c: creating device node '/dev/vcsa2'
Jan 7 19:57:41 aitsurv udev[2697]: udev_rules.c: no rule found, use kernel name 'vcsa5'
Jan 7 19:57:41 aitsurv udev[2697]: udev_add.c: creating device node '/dev/vcsa5'
Jan 7 19:57:41 aitsurv udev[2726]: udev_rules.c: no rule found, use kernel name 'vcs7'
Jan 7 19:57:41 aitsurv udev[2726]: udev_add.c: creating device node '/dev/vcs7'
Jan 7 19:57:41 aitsurv udev[2728]: udev_rules.c: no rule found, use kernel name 'vcsa7'
Jan 7 19:57:41 aitsurv udev[2728]: udev_add.c: creating device node '/dev/vcsa7'
Jan 7 19:57:41 aitsurv udev[2737]: udev_remove.c: removing device node '/dev/vcs7'
Jan 7 19:57:41 aitsurv udev[2739]: udev_remove.c: removing device node '/dev/vcsa7'
Jan 7 19:57:42 aitsurv udev[2747]: udev_rules.c: no rule found, use kernel name 'vcs7'
Jan 7 19:57:42 aitsurv udev[2747]: udev_add.c: creating device node '/dev/vcs7'
Jan 7 19:57:42 aitsurv udev[2750]: udev_rules.c: no rule found, use kernel name 'vcsa7'
Jan 7 19:57:42 aitsurv udev[2750]: udev_add.c: creating device node '/dev/vcsa7'
Jan 7 19:57:44 aitsurv kernel: [drm] Initialized drm 1.0.0 20040925
Jan 7 19:57:44 aitsurv kernel: ACPI: PCI Interrupt 0000:01:00.0[A] -> Link [LNKA] -> GSI 11 (level, low) -> IRQ 11
Jan 7 19:57:44 aitsurv kernel: [drm] Initialized radeon 1.16.0 20050311 on minor 0:
Jan 7 19:57:44 aitsurv kernel: agpgart: Found an AGP 2.0 compliant device at 0000:00:00.0.
Jan 7 19:57:44 aitsurv kernel: agpgart: Putting AGP V2 device at 0000:00:00.0 into 1x mode
Jan 7 19:57:44 aitsurv kernel: agpgart: Putting AGP V2 device at 0000:01:00.0 into 1x mode
Jan 7 19:57:44 aitsurv kernel: [drm] Loading R200 Microcode
Jan 7 19:57:44 aitsurv udev[2780]: udev_rules.c: configured rule in '/etc/udev/rules.d/50-udev.rules[150]' applied, 'card0' becomes 'dri/card%n'
Jan 7 19:57:44 aitsurv udev[2780]: udev_add.c: creating device node '/dev/dri/card0'
Jan 7 19:57:44 aitsurv udev[2780]: udev_add.c: preserve file '/dev/dri/card0', cause it has correct dev_t
Jan 7 19:57:57 aitsurv gdm(pam_unix)[2724]: session opened for user root by (uid=0)
Jan 7 19:57:59 aitsurv gconfd (root-2855): starting (version 2.10.0), pid 2855 user 'root'
Jan 7 19:57:59 aitsurv gconfd (root-2855): Resolved address "xml:readonly:/etc/gconf/gconf.xml.mandatory" to a read-only configuration source at position 0
Jan 7 19:57:59 aitsurv gconfd (root-2855): Resolved address "xml:readwrite:/root/.gconf" to a writable configuration source at position 1
Jan 7 19:57:59 aitsurv gconfd (root-2855): Resolved address "xml:readonly:/etc/gconf/gconf.xml.defaults" to a read-only configuration source at position 2
Jan 7 19:58:04 aitsurv gconfd (root-2855): Resolved address "xml:readwrite:/root/.gconf" to a writable configuration source at position 0
Jan 7 19:58:15 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 1000 - Capturing at 24.39 fps]
Jan 7 19:58:55 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 2000 - Capturing at 25.00 fps]
Jan 7 19:59:35 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 3000 - Capturing at 25.00 fps]
Jan 7 20:00:02 aitsurv crond(pam_unix)[2999]: session opened for user root by (uid=0)
Jan 7 20:00:02 aitsurv crond(pam_unix)[3000]: session opened for user root by (uid=0)
Jan 7 20:00:02 aitsurv crond(pam_unix)[2999]: session closed for user root
Jan 7 20:00:04 aitsurv crond(pam_unix)[3000]: session closed for user root
Jan 7 20:00:15 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 4000 - Capturing at 25.00 fps]
Jan 7 20:00:55 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 5000 - Capturing at 25.00 fps]
Jan 7 20:01:01 aitsurv crond(pam_unix)[3012]: session opened for user root by (uid=0)
Jan 7 20:01:01 aitsurv crond(pam_unix)[3012]: session closed for user root
Jan 7 20:01:34 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 6000 - Capturing at 25.64 fps]
Jan 7 20:02:14 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 7000 - Capturing at 25.00 fps]
Jan 7 20:02:54 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 8000 - Capturing at 25.00 fps]
Jan 7 20:03:34 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 9000 - Capturing at 25.00 fps]
Jan 7 20:04:14 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 10000 - Capturing at 25.00 fps]
Jan 7 20:04:54 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 11000 - Capturing at 25.00 fps]
Jan 7 20:05:01 aitsurv crond(pam_unix)[3046]: session opened for user root by (uid=0)
Jan 7 20:05:02 aitsurv crond(pam_unix)[3046]: session closed for user root
Jan 7 20:05:34 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 12000 - Capturing at 25.00 fps]
Jan 7 20:06:13 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 13000 - Capturing at 25.64 fps]
Jan 7 20:06:53 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 14000 - Capturing at 25.00 fps]
Jan 7 20:07:33 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 15000 - Capturing at 25.00 fps]
Jan 7 20:08:13 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 16000 - Capturing at 25.00 fps]
Jan 7 20:08:53 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 17000 - Capturing at 25.00 fps]
Jan 7 20:09:33 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 18000 - Capturing at 25.00 fps]
Jan 7 20:10:01 aitsurv crond(pam_unix)[3088]: session opened for user root by (uid=0)
Jan 7 20:10:01 aitsurv crond(pam_unix)[3089]: session opened for user root by (uid=0)
Jan 7 20:10:02 aitsurv crond(pam_unix)[3089]: session closed for user root
Jan 7 20:10:02 aitsurv crond(pam_unix)[3088]: session closed for user root
Jan 7 20:10:13 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 19000 - Capturing at 25.00 fps]
Jan 7 20:10:53 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 20000 - Capturing at 25.00 fps]
Jan 7 20:11:33 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 21000 - Capturing at 25.64 fps]
Jan 7 20:12:12 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 22000 - Capturing at 25.00 fps]
Jan 7 20:12:52 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 23000 - Capturing at 25.00 fps]
Jan 7 20:13:32 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 24000 - Capturing at 25.00 fps]
Jan 7 20:14:12 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 25000 - Capturing at 25.00 fps]
Jan 7 20:14:52 aitsurv zmc_dvideo0[2483]: INF [AIT_infered_1: 26000 - Capturing at 25.00 fps]
zmdc.log
Server starting at 06/01/07 19:57:30
'zmc -d /dev/video0' started at 06/01/07 19:57:34
'zmc -d /dev/video0' starting at 06/01/07 19:57:34, pid = 2483
'zmfilter.pl' started at 06/01/07 19:57:36
'zmfilter.pl' starting at 06/01/07 19:57:36, pid = 2488
'zmaudit.pl -d 900 -y' starting at 06/01/07 19:57:38, pid = 2494
'zmaudit.pl -d 900 -y' started at 06/01/07 19:57:38
'zmwatch.pl' started at 06/01/07 19:57:39
'zmwatch.pl' starting at 06/01/07 19:57:39, pid = 2500
zmpkg.log
Command: start
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl check'
Removing shared memory
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmfix'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl status'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmc -d /dev/video0'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmfilter.pl'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmaudit.pl -d 900 -y'
Executing: su apache --shell=/bin/sh --command='/usr/local/bin/zmdc.pl start zmwatch.pl'
Blaise Pascal
jameswilson
Post by jameswilson »
personally if it were me
#BTTV 4 port card
alias char-major-81-0 bttv radio=0 pll=1 tuner=0
id remove those alias things as i have no idea what they are and have never used them
is normally all i put in my modprobe, but cordel will probably put me and you right when he gets on
James
James Wilson
cordel
Post by cordel »
Those otions look fine, you could set tuner=4 (setting for no tuner) and I don't remember off the top what the setting is for no radio.
Everything shows that you should be working.
If you would like and it's available, you can email me the info to take a peek and see what might be amiss.
jameswilson
Corey what are those alias things then?
James Wilson
cordel
Post by cordel »
I'm gona cheat the discribing the alias, from cli
man modprobe.conf
alias wildcard modulename
This allows you to give alternate names for a module. For example:
"alias my-mod really_long_modulename" means you can use "modprobe my-mod"
instead of "modprobe really_long_modulename". You can also use shell-
style wildcards, so "alias my-mod* really_long_modulename" means that
"modprobe my-mod-something" has the same effect. You can’t have aliases
to other aliases (that way lies madness), but aliases can have options,
which will be added to any other options.
I whould also drop the second alias so that you have
jameswilson
oh i see
char-major-81 must be a really long name then lol
James
James Wilson
amp
Post by amp »
Thanks Gents,
I made the changes and I am rebooting.
Thanks!
Blaise Pascal
amp
Post by amp »
I am still getting the blue screen. There is a flicker of a black horizontal line / bar that periodically goes across the screen.
Cordel, it will take a day or two to configure the camera client on the lan, redo the iptables to open access to the camera client for you.Then I'll send the information to you.
Here are the Source settings
Device Path : /dev/video0
Device Channel : 0
Device Format (0=PAL,1=NTSC etc) : 0
Capture Palette : RGB24
Capture Width (pixels) : 384
Capture Height (pixels) : 288
Orientation : Normal
What else should I look for? What other ideas to try? I am wondering about the "open / closed session for apache / root" in the /var/log/messages. Any ideas?
Anthony
Blaise Pascal
cordel
Post by cordel »
If you have a blue sceen, this usualy means that zm is corisponding with the card. Are you sure you have the camera in the right port and that it has power?
If you have x and tvtime installed you can check to see if you are getting video from the camera.
amp
Post by amp »
power is on camera.
This is a local camera. Does it have a port?
tvtime: went through many settings. Still have blue screen with flickering black line. tvtime output show blow.
Restarting tvtime.
Reading configuration from /etc/tvtime/tvtime.xml
Reading configuration from /root/.tvtime/tvtime.xml
/root/.tvtime/stationlist.xml: No existing PAL-60 station list "US-Cable".
videoinput: Can't get tuner info: Invalid argument
Restarting tvtime.
Thank you for using tvtime.
xawtv: Went throught many setting - Blue screen black flicker.
Gerd Knorr <kraxel@bytesex.org>
[root@aitsurv ~]# xawtv -c /dev/video0
This is xawtv-3.95, running on Linux/i686 (2.6.11-1.1369_FC4)
Warning: Cannot convert string "-*-ledfixed-medium-r-*--39-*-*-*-c-*-*-*" to type FontStruct
[root@aitsurv ~]# xawtv -c /dev/video0 -bufcount 8
[root@aitsurv ~]#
Anthony
Blaise Pascal
cordel
Post by cordel »
Did you stop zm before starting xawetv and tvtime?
Depending on your zm settings, if zm is capturing from the card it might continuosly scan through the ports.
This might be seen as a blue screen with a flicker though tvtime or xawetv.
Other wise you might try card=10
