i am new here. Well, kindof. I have now set up a working zoneminder pc on mandriva 2006, building everything from source except for Cambozola and a couple of other select items. I am using the 315 dollar with shipping gadspot ak-16's (7 of them presently, and soon to be 9) to monitor a corporate environment (cherry packing house).
we have a very slow internet connection (256k upload), but if anyone would like to root around and see what is set up, please email me. I have a temporary account set up for some friends to check it out....
I am also a relative Linux newb... have had some experience in the past, but not much
The reason i say i am kindof new, is because for the last week while i was setting up the server, i was searching these forums a lot for answers-- and finding a lot of answers about where to look for errors, etc. so..
THANK YOU to EVERYONE that takes the time to answer posts, for your patience, caring, time, etc. And even more thanks to Phil for making ZM!!! and giving me an excuse to get linux experience on the clock
This helped me track down all of the running problems (mostly .so locations, and the memory issue in the FAQ) except one::
It seems that the permissions change randomly on all of the files i have in my cgi-bin directory. The executable flag gets removed from them.
This causes streaming to cambozola not to work, until i do a chmod on all of the files in the directory to once again allow excecution(the directory itself doesn't have this issue- only the files in the directory) .
WAIT!
OK, i just Found the problem-- it was logged in the messages log-- hadn't ever caught it there before...
For those of you using Mandrake or Mandriva, this will be a problem, depending on your msec settings (mandriva security)
here is an excerp from the log:
hmmm as i am on a windows box ssh'ing into the vi, i'm not sure how to do this, so i will type it verbatum:
(Date) (Host Name) msec: changed mode of /var/log/cgihome/zms from 740 to 640
it does this for several directories.
I will be moving the location of zoneminder, i believe, to a newer/larger drive which may solve some of this problme (is it stemming from my entire ZM install being in the /var/log directory?)
any thoughts?
thanks to everyone again!
Camden
